For all of you why are wonder what happens here a UI has changed and it is low, mid, high and double click for strobo.
Springs are super quality as a reflector is also.
Problem is that driver is glued
I got an Philips Luxeon V NW which is a little bigger than XP-L V3 HI as you can see.
Measurements for this led are :
High - 1455 lumens
Med - 334 lumens
Low - 41 lumen
Tailcap current is 5.12 A.
I’m not satisfied with the throw, if you want throw avoid a Luxeon V version.
It is better that I got Luminus SST40 CW then then dedome it or order dedomed version and just swap.
As I can see here is no chance to reflow an Luminus SST40 CW since led’s are with different dimensions, Luxeon V is smaller. If anyone know if this can be reflowed plase tell.
Maybe I didn’t understand. I thought you were going to try to reflow the SST40 on the same board as the Luxeon V. If you are going to replace the whole MCPCB then it will be fine.
Yeah, like you I also ordered more after putting it to use. It’s a great balance of light and throw. The price is really good and it fits in my jacket, albeit a little bulgy. I am surprised at the output considering the relatively small package when compared to the MF02.
