How did you remove the inner spring without the outer? Can it be twisted out? I would just remove both then put the big spring back as it easy with a solder iron.
I don't know how to tell a Be/Cu spring from a regular. I thought I explained it in detail. Basically, yes, the inner spring was twisted out - on the driver side, not the tail inner spring.
The spring pad is as wide as the spring so there is no pad space outside the spring to add solder - I always struggle with an iron on this setup. I'd rather just remove the inner spring if not that difficult.
Me too, never understand why they do this. Hard to replace spring with a better one too cause it only fits specific sizes. Tool AA I modded had this but not even all the way around just 3 slots along the circumference
@TomE, use magnet to check if these are BeCu or not.
Sofirn told me they should be using BeCu.
I don’t know which alloy they used, but it should be at least BeCu C17200 22% IACS.
Not the best, but still adequate.
If the magnet actually sticks, then oh boy.
If not, it’s at least a copper alloy.
Throw is surprisingly decent, in spite of a few things that induced misgivings. Sheer output can do that, a longer distance lux measurement will be interesting.
Tom, have you had an opportunity to run it long enough to get a feel for the thermal properties? The design certainly looks adequate, just wondering if it works in reality as it appears it should.
Yea, I agree - does throw pretty decent. My #'s taken at 5m too, and it's a non-treated glass lens, but who knows - it still may perform well I recall the Q8 lens did well in clear, not much of a bump goin to a UCL/p. Didn't run it long, but even after the 30 secs and the throw tests, it feels a bit toasty, but really can't tell til it's really run continuously for a few mins.
Didn't mention this yet, the finning is nice but has some sharp edges. It doesn't appear to be a high qual anodizing because I can see some marks on those sharp edges. I suppose at this price and this size, I wouldn't expect much better. Kind of reminds of the old TrustFire J-18's, AK-47's, etc., but the threads are definitely nicer.
But don't get me wrong, overall I really like this light, lots of power and great UI even stock. I gotta look into changing the LED though to something more NW.
This turned out really good! I think we have to thank Jason for pursuing it with Sofirn, not sure of others were involved, but --
Just ran a 3 minute turbo test, temps taken on the outside:
1 min: 33C
2 mins: 42C
3 mins 49C, and it stepped down, but dbl click brought it back up
The wires were easy to come off from using the bigger iron tip and 750C temps.
Driver pics:
Looks like a fairly simple design, might be equal to a FET+1 because that 3 legged part near the bottom appears to go out to the LED- side, same as the FET does. Looks like we could get a bump with a FET swap, perhaps.
The CTKS part is probably the LDO, but didn't trace it out yet.
The MCPCB is actually 42 mm x 1.5 mm. Back side is pretty smooth, no burrs, good amt of thermal grease, though I'd still prefer MX-4 in there. Shelf looks ok but didn't test it for flatness yet. I still would guess the wires are 18 AWG. I think the FET is the NXP MtnE sells here.
I took some pictures of SP70 beam last evening. Do you notice the boats of the 2nd picture? It's dragon boats preparing for Duanwu festival celebration.
By the way, SP70 alone and bundle are available on amazon.com now! They are on sale as new release. For a bettery price, please contact sofirn for code!
Sofirn SP70 Set and SP70 Only are pre-order on AMAZON US with lower sale price. Flashlight set only $69.99 and flashlight only just $59.59!
Please contact us@sofirnlight.com or PM us on this forum directly to get one with $50!
