I got the sample SST-20 LED’s in the other day and tested them out. The 6500k are CW but really good for that tint.
The 5000k are also great at med-high power levels and acceptable at low power levels, better then XP-G3 or the 219C’s they sent me before. The output is better as well.
We are still hunting down some 4000k 95cri SST-20’s from below the BBL. They are seriously hard to get, they might be a very limited quantity type of deal. Although the fall back are the normal FB4 tint that everyone else is using which are still good. I have been using these in my prototype for awhile now and it really works great.
I don’t care about HCRI even like others do, the SST20 6500K are the best SST20 tint IMO, I’m a huge fan of cool white, hope to see them make it into the production light! TA how many lumens and candelas did you measure with the 6500K?
I didn’t install them in a light to get readings, I just bench tested them as it was too much of a pain to try them in a light for the test (I would never consider using a CW tint in an actual light of mine lol).
They beat the XP-G3 LEd’s and were not far off the XP-L HI numbers though.
It depends on the tint, they were able to get the highest bin in some of them and 1 below the highest in the rest. They are not positive which tints they will be offering in the final production lights yet.
but the Anduril thermal freak out bug is not fixed
hard turbo dropdown is just a think to do a hard stepdown to fix this bug, and we do not want it,
so that turbo is as long as possible available then fading down to a thermal equal level holding steady the set temperature
There will be multiple options for the LED’s. SST-20’s in 4000k 95cri (hopefully with a better bin then has been available before), 5000k 70cri and 6500k 70cri.
The XP-G3’s cost a bit less but if the sample units with the SST-20 test well then I think I can talk them into ditching the XP-G3 unless Banggood demands it for some reason.
The demand for 3000k has historically been so low that honestly they did not consider it and I never brought it up except in passing.
They have been quite open to custom versions of the light if enough demand is shown though, so if there is demand for a 3000k version I bet it could happen.
The benchmark has not really been set for “enough demand” but my guess from talking to them is 100 is a good number to start with but they might need more interest for things that require custom orders.
