That sounds like fireplace mode.
Illumn.com - Flashlights, Batteries, Carry Gear, Intelligent LED Lighting,...
Your trusted source for authentic batteries, flashlights, and more!
Sand/tan D18 SST20 4000k 95CRI ordered…
First light since 11/11 last year.
Now go check if i have enough BT 30Qs in stock.
I just measured my d18 sst20 6500k again. Those are turn on lumen.
Samsung 30q button top. 11740 lumen
Sony vtc5a solder top. 14130 lumen
Yes… Sony vtc5a are the best!
The VTC5D is the new high-drain cell to rule them all
Except there are others… Samsung 25S, Samsung 25R5, Molicel 26R, probably missing some.
We now offer the floody version for the D18, the floody optics offer very smooth beam without any hotspot,
which is good for close-up inspection, or used as a fill light
I’ll give it less than 1 page until someone asks for mixed TIR’s and LED’s
That’s really cool. With so many lumens, the D18 should be awesome as a fill light.
Can we have beamshot side by side Hank?
Thank you, Mike
Or compact work light.
A tripod hole would have been a really great feature for those purposes, although perhaps there are some clamps that can fit around the D18’s body.
A related idea would be a variation on the bezel with a standard photography filter thread. Then a cheap UV filter combined with DC Fix could allow the user to easily switch between focused and diffused. Or you could make a set of favorite tint filters using gels, so you could make a 4000K D18 instantly into a sub-3000K light when you want candle mode to be warmer, or switch to daylight tint for videography fill.
Or you could burn 18 holes in a neutral density filter.
2 sets of batteries purchased, charged and waiting - Samsung and LG just in case one does not fit well. So ready for this XP-L Hi 4000k! Floody is nice and my normal preference, but this is an out of the ordinary light for me and with 18 leds, I think it will flood enough.
Excellent, Hank. I was waiting for something like XPL HD for extra lumens and flood before pulling the plug and buying.
For me personally I don’t use torches for search and rescue etc so it’s nice to not have the hotspot glare for walking or photography etc. Nearly all powerful lights now have a 500m+ range and I don’t need that with a tree 3 foot in front of me.
That’s sweet. Thanks hank for offering this flood version.,
My last one question. Is it possible to make a d18 MULE ?
I think if you remove the optics and the board on top of them, it should work okay as a mule. The MCPCB is screwed down.
Sony vtc5a solder top. 14130 lumenYes… Sony vtc5a are the best!
Thanks for this information! Sounds like so far the VTC5A are the highest confirmed output for this light? Is it safe to assume that the VTC5D output would be the same?
Samsung 25S do better than VTC5A, considerably better. And the new 25R5 from Samsung seems pretty comparable in my early tests, as well as the Molicel P26A. All three of these get ~15,500 lumens in a 50.2 equipped Q8. (Think of 4 3V 50.2’s as the same thing as 16 XP-G3 emitters)
To my understanding, the most high-drain 18650 so far is Samsung 20S, a true 30A cell. Samsung 24S/25S, Murata VTC5D/VTC6A, LG H26, Milocel P26A/P28A are also pretty good.
HKJ’s comparator is a great place to look and compare. The 20S may deliver a burst of power initially, but at only 2000mAh capacity it’s going to fall very fast under these heavy loads. Gotta look at the compromises and weigh your needs…
Sony vct5d is nothing special when I test in the flashlights. I find Sony vtc5d gives similar output to Sony vtc5a… Sony vtc5d is much more expensive than vtc5a…
Illumn just got in some cheaper VTC5D that aren’t rewraps, not much more than VTC5A.
