I had thought I understood that moon was an independent setting, I didn’t realize though that because of that you couldn’t enter the ramp at the lowest level from turn on… that potential to come on in high is really a killer, really going to have to look into changing that one.
It's not a show stopper for me, and think for most it would be ok.
But because simply that I can, I should really look into reverse engineering the circuit a bit more. Looks pretty straight forward as a FET+(device), if so, then I could attempt an MCU swap - swap in a ATtiny85 for the PIC, then run full NarsilM or Anduril -- I've done an MCU swap before, recently for a headlamp.This design is probably superior to our classic FET+1, just wish I knew what that 3 legged part is that is used in place of the 7135. Would help to know to see if it's a true amp regulator, if so, how many amps, and if it can take high rate PWM.
Man that really sucks. I’m having the same problem with the SC26’s I mentioned earlier. The immediate blast to the last used level has made them both shelf queens :weary:
Maybe Sofrin can change the firmware for the BLF edition??? If not, I guess I’ll be learning how to flash firmware soon…
Was I dreaming, or did Sofirn in the last few days send an offer for discounts on a lot of lights and invite us to share it to friends, something about mentioning “group 4” or words to that effect?
I know some public service folks who’ve been interested in the Sofirn lights I routinely carry when doing volunteer work, and want to pass the info on.
Pointer or cc welcome if anyone recognizes this. I don’t find it among PMs, nor in email, nor in browser history.
Anyone found any tricks to increase output on the SP70 yet? Resistors, heavier gauge wires and etc? Just curious, I know it’s coming. I would love an SMO reflector just to see what it would do.
No harm meant or taken. I just kinda look at it as, that’s just what a lot of us do. Like the Q8, people just upgraded a few things to get a little more output so I assumed someone had already started working on ” upgrading ” so to speak. I took the tail switch out of my L6 and put in the SP70 and got another 150 lux on my meter. It has BlueSwordM’s springs with a bypass on it, but I switched it back. Just wanted to see the difference. Which visually you would never be able to see. Just numbers at this point.
Yep, there's some room for improvements. My previous posts (post #1951) documented a gain with spring bypass's, plus you could swap the driver for a 30 mm one which we have for replacing the L6 stock driver, etc. Also if you stay with the stock driver, could swap the FET with an Infineon for example. You should get some boosts.
As Dale said though, it's a pretty good "BLF" caliber light to begin with, great for non-modders to get a mod level light, or can be additionally tweaked by modders, just like we did with the Q8's for example.
I'm thinking/guessing it's about a 5700K LED - wish I could test for that. I have spare P2 5700K's, but I'd prefer a 4000K myself, so think I'll order them from Arrow since the P2 4000K's are so cheap.
A note for batteries: In my area, the local Batteries Plus Bulbs chain does tack welding of cells. While they can't attach two lithium cells together, they can add "nipples" (aka button-tops) to a flat-top cell in this style, given they have a nipple that fits and all that. Since I can't find the button-top Shockli 5500mAh anymore (I got two from Mtn for my L6, but now he has flat-tops), I'm going to get flat-tops and have this done for $0.50/batt.
Solder blob'n is soooo easy, and only needed on one of the cells, plus lower resistance than typical button tops. I did a few cells the other day, no problems. Just say'n...
The N4 is even cheaper at around $6.50 each. I bought several a couple months back. Output may be down slightly from the P2 but I’m not sure it will be extremely noticeable.
I wasn’t saying the SP70 shouldn’t be modded, if that’s your thing then by all means, mod away. I was merely reminding some of the interested parties that it doesn’t need it. Modders know what can be done, part of the fun is finding out where the gains are, if there are any. Chop it, swap emitter style completely, Cerakote it…
