It only makes sense now because they dragged their feet so much sourcing other LED choices. It’s like they are doubling down on dumb choices to fix their previous mistakes.
They should’ve just taken the 20% customs taxes hit on the LH351Ds from Mouser, maybe increase the LH351D’s light price to 31-32$US, and be done with it.
For the record, they’re welcome to put a bunny on the tail of mine AND a hole in the pocket clip if they also engrave “Spare Parts Edition” on the body. I want a font that looks either like stenciled spray paint or children’s crayon writing. :sunglasses:
yea i know, i would pay 35$ easy if that emitter would be possible soon which was also the reason i jumped in on this light but guess not for the moment.
I am full of gratitude that CCT is a topic for discussion with this manufacturer. Some other manufacturers just keep cranking out lights with angry blue tint and low cri no matter what we say.
So, thank you everyone involved and thank you Lumintop for at least trying to accommodate our very picky membership (myself included).
The Wuben TO50R HC is a 21700 quad with USB charging, a boost driver, and 90 CRI LH351Ds. Zebralight also uses them and has their lights made in China.
But Zebralight has its official headquarters in the US, and Wuben lights usually aren’t cheap unless you get them from BLF group buys. Neal and Lumintop may not have access to the same kind of supply chains they do. Sofirn, on the other hand seems to me to have much more in common with Lumintop as a company. It would surprise me if there are things Sofirn can get with relative ease that Lumintop cannot.
It’s definitely nice that companies like Lumintop pay more attention to enthusiast groups like BLF. What we get may not be perfect, but it’s a whole lot better than what’s available elsewhere.
I got a surprise visit from DHL with a FW3A sample. I’m still testing it, but here are some initial notes…
The good:
Everything seems to work fine so far.
The optic is the correct type.
The spring hasn’t had anything flake off like in the previous sample.
The driver spring is slightly shorter to accommodate slightly longer cells.
The driver appears to be at the correct depth this time.
Button-top unprotected cells fit. I tried one 66.8 mm long and it was fine.
The driver and tail PCBs appear to have been upgraded from a green board with silver-colored traces to a purple board with copper traces. It’s also really clean and has extra labels on it, while the previous board was fairly dirty and somewhat damaged.
The dark-colored clip doesn’t use black paint like on a SK-68 or a SWM V11R. It seems to be a different type of finish, like it was oiled and heat-treated or something like that. It looks like polished hematite, or perhaps smoked chrome or gunmetal chrome. I don’t know how durable it is, but it looks nice.
The bad:
The clip ring has expanded from 25.5 mm to 26.1 mm in diameter, so it sticks out a little. I already asked about changing this, but it sounds like the clips have already been produced so it’s too late to change.
Other:
The tail is not glued.
The clip is a bit more stiff than the earlier versions.
The driver is still very slightly off center, but apparently not enough to effect anything.
The driver retaining ring on mine seems pretty stuck so I haven’t been able to get it out to look at the top side of the driver. I probably just need a better tool though.
The button is somehow even clickier now than in the previous sample. The feeling has really improved a lot since early prototypes.
It’s not perfect, but it’s pretty good. Unless something goes wrong in testing (like if other sample units don’t work), it seems like it’s probably ready to ship.
