[BLF special edition light] new Sofirn AAA twisty high CRI Yuji 5mm LED (CCT 3200K or 5600K) for 6.50 USD
2955 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 15 hours 26 min ago
xevious wrote:
amars7 wrote:
Call me crazy but I ordered 5×2.5mm magnets, the half millimeter leaves the perfect amount of room for a dab of epoxy on the back of the magnet. Place a piece of wax paper over something magnetic and set the light on it (standing upright), that way the magnet will be at the exact right height, then leave it to dry for a few hours at least.
Where did you find 2.5 mm x 5 mm magnets? I’ve only seen them in whole number increments, not fractional.
I guess Simon from Convoy sells them in his store in AliExpress!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
xevious
xevious's picture
Last seen: 20 hours 25 min ago
djozz wrote:
It does depend on the magnet though, some stick better than others. I coincidentally bought a batch (3×5mm) that makes the C01 easily stick in all positions.
As I mentioned earlier, not many are able to measure the strength of the magnetism of these magnets, so sellers get away with everything, so in good ol’ chinese tradition everything is indeed what they sell. In Europe we have supermagnete.de, not that more expensive than Fasttech or Banggood, that makes a point of actually selling what they claim, and I have never got bad magnets from them.
I spotted that tip about using wax paper and resting metal on the top so that the magnet sets flush to the end — that’s a really good idea. Wish I’d seen it earlier. Mine sits maybe 0.25 mm below the surface, but the magnet still holds pretty strongly. It’ll only work with it on raw exposed metal (painted will work, but it slips) and it will naturally pivot to put the magnet at 12 o’clock.
The magnets feel very strong, and they’re difficult to separate. So I’m convinced they’re decent quality.
I tried to dissolve the super glue with acetone, but it’s not getting in behind the magnet… so it won’t come out. I expect I’d have to drill into it to break it, then pull the pieces out.
Thanks. I don’t know how much stronger they’ll be compared to the ones I already have. Can you adhere the light to metal with the magnet positioned at 6 o’clock?
slowtechstef
slowtechstef's picture
Sofirn just posted a message on Facebook that the final 30 lights of the Original C01 (color red, 5600K) will be sold on Amazon.com for 6.50 USD.
—> Link
Henk4U2
Henk4U2's picture
Last seen: 20 min 31 sec ago
slowtechstef wrote:
Sofirn just posted a message on Facebook that the final 30 lights of the Original C01 (color red, 5600K) will be sold on Amazon.com for 6.50 USD. —> Link
Amazon(dot)com means: NO EU.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Lagittaja
Lagittaja's picture
If the magnet wasn’t a tight fit there’s no need to drill it, just heat the tube up.. Cyanoacrylate releases/breaks down/softens/whatever at higher temperatures.
Depending on the grade it’s strength retention drops to 50% somewhere in the neighbourhood of 80-120*C. Couple hundred degrees celsius should drop it well below 20%. Sure there’s High Temp grades out there as well but I highly doubt you used such a glue.
slowtechstef
djozz wrote:
You should get one of the BLF-edition C01S lights, they should be available one of these days. I expect not as indestructable as the C01 (still very sturdy), but more output, low and high modes, bare aluminium without finish, and a nice BLF marking.
Djozz, thanks for the pointer.
That bare aluminum look Love
I am going to dress up at least one 5mm-C01 head with a bare aluminum SST20-C01-BLF body Cool
Also great Sofirn adds a BLF marking to give credit to the origin of the design.
gchart
gchart's picture
Last seen: 6 hours 7 min ago
You could carefully (gloves, eye protection, outdoors…) give your C01 a bath in lye (drain cleaner / sodium hydroxide / etc) to strip off the anodizing for a bare-aluminum finish. Just apply some petroleum jelly or something to any areas where you don’t want it intruding (threads, in the reflector area, etc) and then just clean it off after the bath.
xevious
xevious's picture
Yeah, only problem is that I have a tritium vial installed now. That would likely not survive the heat…
slowtechstef
Thanks for the suggestion to go with lye for removing the anodization. Already wanted to try out that to remove the anodization in the tritium slot.
Omega_17
Last seen: 10 hours 29 min ago
We need a similar BLF edition of this fantastic AA light!
https://www.aliexpress.com/store/product/Sofirn-New-SP10-V2-0-LED-Flashlight-AA-14500-Flashlight-EDC-Pocket-Light-Cree-XPG2-550lm/2933049_32841154512.html?spm=2114.12010612.8148356.3.17944773ZjzAJu
Hugh Johnson
Hugh Johnson's picture
Last seen: 15 hours 6 min ago
It sounds like a good idea. However, a single mode twisty seems less practical for a larger light. Another ui may not differentiate itself. Unsure how this would be implemented.
Omega_17
The stock UI of this light is already perfect its just the stock LED that can be greatly improve with a Luminus SST-20 95CRI and maybe a new unique color as a bonus?
iamlucky13
Last seen: 6 hours 39 min ago
I think Omega_17 is suggesting a BLF-edition SP10 V2, not a AA version of the C01.
That could be a high CRI emitter, and possibly a different firmware. Unfortunately, Narsil or Anduril would probably require a different driver, which is more work for Sofirn, and would likely mean 14500 batteries only – no AA support.
It would be a very interesting product, however.
Geuzzz
Geuzzz's picture
Last seen: 51 min 33 sec ago
Press and hold to turn of…
slowtechstef
This is the C01 end.
Sofirn AliExpress states:
Quote:
“Sorry, this item is no longer available!”
R.I.P.
Sofirn C01 – BLF Sepcial Light
November 2018 – April 2019
“Yuji golden glow
made-in-China potted light
end of an era”
xevious
xevious's picture
I was going to get another, but the Jetbeam U is only $2 more… beautiful finish, anodizing, and I like the multi-mode. But I’m glad to have one C01.
iamlucky13
Do you mean $2 more than the C01s?
I think the cheapest I’ve seen the Jet-u for is $14.
iamlucky13
slowtechstef wrote:
R.I.P. Sofirn C01 – BLF Sepcial Light November 2018 – April 2019 “Harbinger of low-budget high-cri; end of a 5-mm LED flashlight era.”
This project came and went so quickly!
buck91
buck91's picture
Last seen: 5 days 16 hours ago
Love my c01 lights, though I wish the beam was a bit narrower. Super excited about the c01s. Have one so far but holding out on more until if/when they release a L-H mode order.
xevious
xevious's picture
I bought one for $9, and a 2nd one for $10. Usually there’s a coupon floating around. For one I used a $4 off AliExpress coupon. The other was on sale.
lotrbfme
lotrbfme's picture
Last seen: 4 days 8 hours ago
You could ve used the coupon for the C01 also so its still the same difference
sbslider
sbslider's picture
Last seen: 5 hours 1 min ago
—> Link
all gone.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Macka17
Last seen: 1 week 2 days ago
Buggar it.
You lot are 16 hrs ahead of us..
We can Never catch up clock wise..
jon_slider
jon_slider's picture
Last seen: 4 hours 34 min ago
they are still on ebay
xevious
xevious's picture
Well yes, but for more than double the original selling price. Ughh
Barry0892
Barry0892's picture
Last seen: 2 days 2 hours ago
Actually sofirn change SP10 V2 to SP10S by using LH351D 5000K 90CRI, and same UI.
If you like a BLF version, I think use Anduril UI is cool. But it needs Toykeeper’s help and a interest list. Big Smile
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
Eraursls1984
Anduril, AA, count me in! 14500 only, meh.
lightboks
lightboks's picture
Gizeh Magnets fit? Awesome. I harvest those whenever I find an empty pack. Was too lazy to research which magnet might fit the c01. This is perfect. Just wait and they will come to you for free.
lightboks
lightboks's picture
Oh yeah. I will take three or four of these. AA/14500 SP10v2 with Anduril. Yeah. Perfect
Please make some other colors than red and blue. And make one with clear anodizing or in stainless steel please Smile
Look at the Astrolux A01, they have a pretty green, orange, purple, a nice grey..
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 hours 57 min ago
Barry, guys….can we please move the discussion about SP10S and Andúril to the general Sofirn thread, see link below? I try to collate all the information into the corresponding thread about new lights whereas this thread should be about the C01 only. Wink
http://budgetlightforum.com/node/63764
Thanks a lot for your understanding.
Luminous and wired, we'll be glowing in the dark.
