Sorry, thanks, loose driver is not a problem
Low-High is more important for me. Loose driver as long as it doesn’t affect reliability is ok. If they have to glue the driver, it’s not a problem for me. I plan on getting 3-4 of these.
Yes.
This is the light that should’ve a glued driver.
I’m not sure that they will glue the driver, it was my assumption that if we had to choose, we rather add some glue to the driver ourselves than have the UI wrong.
Yes.
Low-high with a glue driver C01S would be great.
And I wonder: Is there any possibility that I can exchange the sequence of modes of my C01S, just by modifying, adding or removing some of the solders of the current driver, but without having to disassemble or reinstall driver components?
For me the sequence of modes is not essential, but I prefer low-high to high-low.
In for several units in raw aluminum
The mode sequence is changed by Sofirn by changing the software as I understand it.
OP updated
@Lux-Perpetua, ask if the drivers can be glued by Sofirn themselves.
Glue is perfectly adequate here.
I‘m not involved into this BlueSwordM. Maybe Jos can forward this request to Sofirn.
Oh ok then.
Or maybe I could just message Sofirn myself.
I will ask Barry about it
Any news?
What happened to the BLF edition?
Following for BLF Edition.
No, that's the "normal" C01S that is also linked in the OP. Sorry to disappoint you.
No ETA was communicated yet. Barry did tell me that they will glue the drivers if after re-assembly they are loose.
Posting to follow, interested in the BLF version.
Without any further comment, Barry sent me this pic. So I have no status info to share atm.
