Maybe lexel can assist on this project?
With a 14500 cell it would be easy… just run it like a normal BLF light. The tricky part is running it from a regular AA cell. It would need a MCU which runs at much lower voltage, or some way to boost the voltage even in standby mode. Or maybe some clever way to wire the switch to the boost circuit so it would enable the boost hardware when the button is pressed.
I’m not sure how the current driver works though; I haven’t seen any details on it. So figuring that out might be the first step.
Interested!
AA is not a big deal to me on this one. Prefer 4000K, but 5000K is fine.
Looking forward to this becoming a reality.
Interested
I would add one to my collection. Can’t see carrying it everyday due to the side switch. I manage to turn on my tail switches in my pocket. Guess how I figure that out.
Burn!
interested
Throwing in my 2¢ (adjusted for inflation)…
I’d be okay with 14500 only, but alkaleak/NiMH compatibility would be nice for the muggle.
Dunno what the fascination is with “clear”, but to me it looks kinda cheap. Stick with black/red/blue. I got a “clear” or “silver” or whatever ’32v2, which is nice, sure, but I still prefer my Mystery Color ones.
Dunno what’s wrong with the UI. I got a couple of the original A version (just l/m/h, no firefly), and B versions (f/l/m/h), and they’re fine. No complaints. The gf loves hers, no complaints either, but might not like too complex a UI.
I got a GTmicro, played with it, it’s nice, but it’s still sitting in a box. Last thing I want is a click-on/click-off light in my pocket that can set my pants on fire or at least burn my crotchal area if the light accidentally gets turned on.
And for the love of B’harni (pbuh!), get a decent non-chrome deep-carry clip, not the typische cheap-looking (even if quite sturdy) Thorfire/Sofirn clips. They grab and hold just fine, but look like an afterthought. “Whoa! We forgot to add a clip! Here throw a bunch of these Generic Clips in the production bin and see if they’ll fit…”
Interested
An AA/14500 Anduril-based flashlight with high-CRI LH351D would be interesting.
Hope the AA/14500 hurdle will be overcome.
Interested, if BLF code could work on Nimh, seems worth the challenge alone.
(Thank you for any one directly helping, wish I could contribute)
Also thinking ahead to a AAA sub-70mm light using Anduril, Imagine C01s with ramping.
The problem lies with how boost converters work... At turn in they have to start up the boost controller ic, it has to energize the coil, the coil has to saturate and only then will there be output [obviously extremelty simplified] . Those things don't happen instantaneously and doesn't coincide well with square wave pwm that BLF firmware all uses as the output from the MCU.
I've looked into this a lot, needing very similar specs. at work as we would need for the flashlight hobby as well. I never found one suitable boost controller (1.2v in / ~4v out, >2A, PWM dimming) that meets all needs. Hell I only ever found one or two that met the first two requirements, ignoring being pwm dimmable! Sadly not much is designed to run off single NiMH...
If it happen count me in.
Interested.
From what I can gather the SP10B uses an XC9104 as the main booster - output PWMed via FET not sure about that, but PWMed in some way - plus what I believe is an ME2188 as the auxiliary booster (always running, no-load input current in the range of 10µA) for the control circuitry.
Adapting Anduril to run on this shouldn’t be too hard, it would be 1-channel PWM only (though one could probably do proper moonlight off the aux supply and a dedicated pin+ resistor).
@Toykeeper - this would make use of that control pin we talked about in the FSM thread, remember? I know that Lexel knows what I mean
If Sofirn were to keep the boost circuitry - it seems to do a fairly good job at regulation - then 14500 and AA should work fine. But you’d have to come up with some way of doing the LVP for 2 different chemistries (and this would have to use the old-school voltage divider of course)
Yes, please …
Intrested for sure, would love one with a Samsung LH351D 5.000K 90CRI
And bring back the OP reflector !
My sentiments exactly.
OP is updated. Thanks a lot for all your contribution here.
Interested
