If it is a capacity battery, such as 1A current output, the button top internal resistance has little effect.
battery with pcb will add more AC IR,
If it is a high-power battery, it will have a greater impact.
For example, if the AC impedance of samsung 30T, 7mOhm is changed into 10mOhm by adding a button top, then the continuous discharge is only about 30A.
Barkuti
(Barkuti)
April 22, 2019, 3:45am
157
I understand vapcell Dennis , but FaintReality reports twice the internal resistance of an EBL 14500 for his Vapcell 14500. I know his figures are far from real DC resistance values but to me that means his Vapcell 14500 is likely well above 200mΩ of internal resistance. So pretty bad. Being so removing the button top and using a rotary tool with a grinding bit to gently fix the welding remnants is a wise choice.
Barkuti:
Using the Xtar Dragon VP4 plus, I got the following results from my current 14500 button tops:
EBL #1 - 54 mohm
EBL #2 - 49 mohm
EBL #3 - 49 mohm
EBL #4 - 54 mohm
Vapcell (gold) - 103 mohm
Efest (2018 purple) - 29 mohm
So although the Xtar may not be 100% accurate, it is more than sufficient to use for comparison sake, which raised a red flag when comparing the Vapcell to the Efest and the cheap eBay EBL batteries.
I would remove button top and re-wrap, but these batteries are for a Sofirn SF14 V2.0 which requires button tops. I may just do it out of curiosity sake…
FaintReality:
Barkuti:
EBL #1 - 54 mohm
EBL #2 - 49 mohm
EBL #3 - 49 mohm
EBL #4 - 54 mohm
Sincerely apologize, please let me know your order number, I will call Ail Express customer service to contact you, compensation to you.
contactcr
(contactcr)
April 25, 2019, 10:08pm
160
DC IR during 3.5A discharge:
Flat top 14500:
Button Top 14500:
I just got the 4 wire cell holder today. Still not entirely sure how relevant or useful this information is.
Barkuti
(Barkuti)
April 26, 2019, 12:27am
161
Vapcell fellows please correct the thread's title. “Ture rating for you on flashlight batteries,Buy the battery now to send free zipper case” is wrong for many reasons. I understand the culprit here is a language barrier, so let me help you. “Ture” is a misspelling; “batteries” are just batteries, no need to specify “for flashlights”, “for vaping mods” nor ;-) “for anal hair clippers”; the last part is the worst one, I guess what you want to mean is you send a free zipper case with each pair, don't you? Since you seem to sell your batteries in pairs this is what I would write in the title instead:
Vapcell, true rating for you on batteries. Buy now and get a free zipper case!
Cheers
CRX
(CRX)
April 29, 2019, 10:42am
162
Well…
After nearly a month of exciting anticipation waiting on the new Vapcell 16340 cells to be delivered the package finally arrived.
Just the package.
An empty box.
Oh, except for some packing material to keep the air inside from being damaged.
Very thoughtful
I need a little help here I think.
g_damian
(g_damian)
May 10, 2019, 10:31am
164
Mine 16340 were missing from the package too. Vapcell offered to resend them.
CRX:
Well…
Just the package.
An empty box.
Very thoughtful :+1:
Barkuti:
Vapcell fellows please correct the thread’s title. “Ture rating for you on flashlight batteries,Buy the battery now to send free zipper case” is wrong for many reasons. I understand the culprit here is a language barrier, so let me help you. “Ture” is a misspelling; “batteries” are just batteries, no need to specify “for flashlights”, “for vaping mods” nor “for anal hair clippers”; the last part is the worst one, I guess what you want to mean is you send a free zipper case with each pair, don’t you? Since you seem to sell your batteries in pairs this is what I would write in the title instead:
Cheers
Dear Barkuti
Thank you very much for your advice. We will improve ourselves.
Have a nice weekend
CRX
(CRX)
May 10, 2019, 2:21pm
166
Interesting. What country? This is more than coincidence now.
What say ye Vapcell?
Vapcell has apparently sent me replacements too so we will see what happens but if I don’t get them soon then yeah…
Here is another test of the Vapcell 14500 with a 8x7135 driver in the meantime:
I hope you will receive it as soon as possible.
Do you know how to delete previous posts on the forum?Thanks
CRX
(CRX)
May 10, 2019, 3:14pm
168
There is a delete button on each of your posts but not for threads.
You need to ask Admin to delete threads.
moderator007:
I received my Vapcell 16340’s today. I ran a 3 amp discharge test on the icharger from fully charged. I got 638mah at 12 min and 45 secs down to 3v.
Down to 2.75v, I got 726mah at 15 min and 25 secs. This test was done at a constant discharge of 3 amps and there’s no doubt this cell will make 800mah or more at a 1 amp or less discharge.
When I started the test the voltage stayed decently high. It started at 3.7v under the load and fell rapidly to 3.6v where it slowly crept down to 3.5v after about 3 mins. The cell done very well holding around 3.5v for awhile.
We have a new 16340 King, less sag and more capacity .
Thanks Vapcell for improving on these smaller size cells. Great Job :+1: .
sounds like a great option!
and I see on page one:
05/04/2019
The new product releases vapcell 16340 batterys with high capacity. Battery with button top , which is
more suitable for flashlight. If you are interested in review or test, please contact me by private letter. and this battery will also sell in Ali-express
I volunteer to do a real world test in my Jetbeam TCR-1, Jetbeam RRT-01, Utorch S1 Mini, Olight Ti S Mini, Novatac, and MecArmy PT-16.
Only One of those lights has built in Low Voltage Shutoff, so Im volunteering to live dangerously, and promise to tell all about it.
I applaud the arrival of this new buttontop INR offering:
contactcr
(contactcr)
May 14, 2019, 8:58pm
170
They are in stock at Illumn now
Agro
(Agro)
May 14, 2019, 9:00pm
171
I see a high current 14500. Oh yeah, finally something worthwhile in this format.
will34
(will34)
May 14, 2019, 9:05pm
172
Where can I order the 10440? Can’t find them in your aliexpress shop.
Barkuti
(Barkuti)
May 14, 2019, 11:00pm
174
https://www.aliexpress.com/store/product/1-dollar-coupon-High-capacity-power-RCR123A-Vapcell-16340-800mah-7A-CDR-3-7v-Rechargeable-Li/1084158_33000319786.html
Why only button top? Batteries are not manufactured that way. I know the answer and despite I can sort of accept it, it is not of my liking.
If anything a wide button top is better, providing extra contact surface.
Cheers :-)
:+1: or a Raised Flat Top like the VTC5A…
