Interested!
Thomas,
Can you check with Barry et al about the possibility of TIR optics? I’m unsure of the use-cases people may have for it, but in a smaller host, I’d assume it’d be for closer-up work rather than throw, so smoothing the beam out with TIR might be good.
Sure, I'll ask him. :-)
Very interested!
Thanks mate!
Interested in 1.
> How does that side switch not activate in one’s pocket?
A click stop at around a quarter turn of the battery tube/tailcap as a way of knowing it’s locked out — would be nice.
Or even a couple or three paint dots on tube and tailcap indicating the lockout alignment.
Or a hot-light thermal cutoff ….
If that effort isn’t successful, a simpler task would be to make the light 14500 only. That should be relatively easy to do in this light.
Yeah, Interested.
I’d buy one if it was available with a 4000K high-CRI emitter.
Interested, if Andúril
In
Interested
TIR would be nice on this light
If its not postible, OP
Interested
For everyone worrying about it turning on in your pocket, have you ever used Anduril? It's electronic lockout is miles ahead of any other I've used. 4 clicks for lockout, and the confirmation flashes are very short.
Compared to something like an Emisar D4 or D1 which has 6 clicks and several long flashes that feel like an eternity.
No, with Anduril, E-lockout is a daily used feature for me.
Combine that with fancy lockout moon mode, which when in lockout, let's your first click be moon, and your second click be a more reasonable brightness of your choosing, all the way up to turbo if you choose.
This way you are much more likely to use your light for brief periods of time without unlocking it. Super duper useful.
I have my EDC D4 with Anduril in my pocket with the first click set to moon and the second set to something like 25%.
And I have a D1S in my car, the first click is set to something like 50%, and the second is turbo.
So your not going to catch your pants on fire, you'll be ok
I’m interested for two
Just to be clear, this is not stock Anduril. People will have to reflash their drivers to get this “fancy lockout moon mode” functionality.
Interested
interested
