Sofirn C01S SST-20 4.000K 95CRI / Low-High version available again!
661 posts / 0 new
Lonelydad
Lonelydad's picture
Last seen: 6 days 16 hours ago
gchart wrote:
Lonelydad wrote:
I used rare earth 5mm x 3mm magnets…
Yup, I could see that. Some magnets are stronger than others, too. Out of curiosity, where did you get your magnets? I’m still thinking about getting some.
banggood.
https://www.banggood.com/100pcs-N50-Strong-Disc-Mini-Magnets-5×3mm-Rare...
You don't really need a parachute to skydive. But you DO need one if you want to skydive twice!
terranaut
can this take a 10440 battery?
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 4 hours ago
No. It’ll burn the driver.
djozz
djozz's picture
Last seen: 10 hours 16 min ago
The C01 certainly not, the C01S no one has tried it. Three options:
*works fine
*works fine but something is damaged so that alkalines and NiMh’s stop working
*the driver fries
Caleb
Caleb's picture
Last seen: 4 hours 18 min ago
Interested in BLF Edition… probably several.
Thanks
missieek
Last seen: 11 months 2 weeks ago
I've got also mine Smile
and here in comparison with small Astrolux with Nichia emitter:
Nice tint, small size. It would be nice if it has a memory.
djozz
djozz's picture
Update: Sofirn finished the BLF edition but the mode order was not changed to low-high Facepalm
They have to remove the drivers to fix that but are afraid that the drivers may end up somewhat loose.
I guess that it is fixable with some glue if that happens so that is how it will be then Flat Stare
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 16 hours 36 min ago
Bedankt voor de update Jos! Ik zal de thread updaten. Wink
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
Gunga
Gunga's picture
Last seen: 2 hours 16 min ago
I guess I’ll skip it. High – low is a no go to me.
shirnask
shirnask's picture
Last seen: 27 sec ago
No High-Lo for me either
djozz
djozz's picture
Some confusing posts above. The idea is that Sofirn will reflash the drivers so that the UI starts with low, as was planned for the BLF edition. The consequence may be that the drivers, having been removed and assembled again, may end up a bit loose. I thought that was a better option than leave the UI the wrong way around.
Is it clear now?
shirnask
shirnask's picture
Sorry, thanks, loose driver is not a problem
Tech25
Low-High is more important for me. Loose driver as long as it doesn’t affect reliability is ok. If they have to glue the driver, it’s not a problem for me. I plan on getting 3-4 of these.
BlueSwordM
Yes.
This is the light that should’ve a glued driver.
djozz
djozz's picture
I’m not sure that they will glue the driver, it was my assumption that if we had to choose, we rather add some glue to the driver ourselves than have the UI wrong.
BlueSwordM
Yes.
Low-high with a glue driver C01S would be great.
Noctiluco
Noctiluco's picture
Last seen: 15 hours 55 min ago
And I wonder: Is there any possibility that I can exchange the sequence of modes of my C01S, just by modifying, adding or removing some of the solders of the current driver, but without having to disassemble or reinstall driver components?
For me the sequence of modes is not essential, but I prefer low-high to high-low.
In for several units in raw aluminum
djozz
djozz's picture
The mode sequence is changed by Sofirn by changing the software as I understand it.
Lux-Perpetua
OP updated
BlueSwordM
@Lux-Perpetua, ask if the drivers can be glued by Sofirn themselves.
Glue is perfectly adequate here.
Lux-Perpetua
I‘m not involved into this BlueSwordM. Maybe Jos can forward this request to Sofirn.
BlueSwordM
Oh ok then.
Or maybe I could just message Sofirn myself. Smile
djozz
djozz's picture
I will ask Barry about it
rost333
rost333's picture
Last seen: 3 weeks 4 days ago
Any news?
lotrbfme
lotrbfme's picture
Last seen: 6 hours 2 min ago
What happened to the BLF edition?
Caleb
Caleb's picture
Following for BLF Edition.
terranaut
is this not the BLF version? i have one arriving thursday, having thought it was
aliexpress link
Lux-Perpetua
No, that's the "normal" C01S that is also linked in the OP. Sorry to disappoint you.
djozz
djozz's picture
No ETA was communicated yet. Barry did tell me that they will glue the drivers if after re-assembly they are loose.
ooeei
Posting to follow, interested in the BLF version.
