TC66C-a powerful Type-C USB tester
very good, my friend
I am waiting for this
Other than dodge_911, has anyone in the US/Canada received their TC66 yet? Mine shipped on 4/4. So far no sign of it yet.
I got mine a couple of weeks ago, delivered to California
you can leave message to RD in your order, let them check the shipping infomation. maybe delay by postal instability
just wait , it will be soon, what’s your order number? I can help check
I'm not in the US or Canada, FYI :)
I hail from the country that brought you such classics as the FAL and the saxophone...
My video will be dropping at midnight, dunno what time that will be over the pond.
I received mine 2 weeks ago.
I saw your video, it is good
do you like it
Yes, I like it a lot. :slight_smile:
thank you very much , hope you like it and tell your more friends
:+1:
Thanks for the review.
Where to buy at a reasonable price? Thanks
Here:
https://www.aliexpress.com/item/RD-TC66-TC66C-Type-C-PD-trigger-USB-C-Voltmeter-ammeter-voltage-2-way-current-meter/32968303350.html
Ask for a 5% BLF discount with your username by contacting them.
what’s the reasonable price?
Aliexpress, check if there is any coupons and discount, I think this price is acceptable.
we adjust the appearance of TC66C, make it easier to understand how to put the switch(power supply switch and PD switch)
“Power supply switch button. When on, you can use system power supply; when off, you can use isolated power supply. For high precision and lower voltage measurement, you can switch to OFF and use micro port to power on.
PD Switch, place the switch on ”OFF” when measuring a device which is charging, PD function OFF; and place the switch on “ON” when do decoy trigger operation, PD function ON. Switch stroke is short so use the switch gently to avoid damage please.”
Every bit of clarity helps.
What is the latest firmware revision?
I see that is Version 1.13
Version 1.13, you can use the PC software to update it to check
