Lumens at 1s are Ahh! and all, but are not really relevant and no one uses that measurement. I think we’d all like to see something more realistic once the output settles a bit. Maybe 15 to 30 seconds or maybe Turn on and 20 seconds so we see how it drops.
Firelight, even the Blue springs benefit from spring bypass. I chopped a D Maglite and used the Q8 reflector with it’s board and XP-L HI emitters, counting on just the springs the output seemed low, a single tail spring bypass gained 500 lumens, I removed the one on the driver and used a solid copper contact. Now the light can make the expected 5000+ lumens on a hot cell.
The collection was joined by Emisar D18.
I will say briefly, I like it very much.
Turbo withstands 30 seconds. When setting the temperature threshold to max, after 6 minutes I was able to warm it up to the temperature of 75 degrees Celsius. Beam profile similar to M43, looks reminiscent of a bejspol stick
Maybe do him cleaning the contacts. I undressed the whole thing, cleaned the contacts, the tube, the brass ring, everything I could. Then I re-greased the threads, twisted and just started to play. The result did not surprise me because I was counting on those 10000. It surprises me a bit, how poorly XP-L HI is. Sky Lumen did not squeeze out too much. Maybe it’s a matter of optics and poor fitting to XP-L HI?
I will be looking at my friends D18 later today, expect to find gains but where and how much remains to be seen. It’s on the mail truck , looking forward to it.
He’s so excited to see what I do to it he didn’t even measure it on his new light box! lol So I have to get readings with a few different cells first, then I can start looking for the improvements…
Original springs. I want to have some fuse. I do not see them as a limitation of power. My measurement is 45A, or 15A for each cell. I use samsung 30Q with the top button, bought on BG. They are slightly longer than those with a flat top, so they also compress the springs more tightly. It can also affect the result. I am very pleased with the efficiency and overall quality. It is a pity that the LEDs are not aligned with the switch. Fortunately, only a little so it does not bother me.
Risky? Aw come on, the lab IS in the dungeon basement for a reason!
Doesn’t the MT-G2 have 72 dies? Don’t I have more than one light running multiple MT-G2’s? Didn’t Richard put 50’s in his 18 emitter TRJ20? Who’s gonna do it if I don’t? Sometimes ya just gotta tear the box up and move on…
Edit: I might not even be able to move up to the larger footprint as space constraints might limit the possibility, so for the time being I will stick with the XP footprint and see where I can take it. W6 LH351D emitters on stand-by.
Yes, I also got the XPL HI’s running on 3x 30Q’s, bit disappointed in the output, was expecting much more, should have stuck with the stock emitters and saved myself $50
On my friends D18 I tested it with button top 30Q’s and it made 13,050 at start, 10,940 at 30 sec…. with Molicel P26A it did 14,270 at start and 11,050 at 30. And was HOT!
I bypassed the springs and recharged the Molicel’s and it made 14,450 at start but stepped down before the 30 second mark, hot for sure!
