There isn’t a second list for the SST-20 emitter type. The list doesn’t track that data at all.
I think what will happen is: As soon as Neal adds the SST-20 preorder option to his store, you should be able to order it with the code from your first message. But that is not confirmed yet. I don’t know how he will handle that.
I got my PM and ordered three since they’re going to have the LEDs swapped anyway and I don’t want to wait any longer. I did get both CCTs so I can test the output and colour for others. Not very hopeful I will receive them any time soon with this volume of orders though.
As far as mods go, this one is pretty easy. It uses a standard triple MCPCB. So basically just unscrew the bezel, unsolder two wires, swap the board, connect two wires, and screw the bezel back on.
Yep, you will get it right about 01:15 CST 28 April 2019 to be exact…._ very early_ Sunday. Provided the script keeps running smoothly, as it appears it has been thusfar. :+1:
Comparing different CCT with the same CRI 70 won’t be as eductional for your eyes and brain than comparing same CCT with different CRI (70 vs 90).
People who are searching for vivid colors are looking for high CRI (Ra = 90 with R9 = at least 60 (80 and more is better)).
When your eyes and brain can make the difference even a 3000°K CRI 70 LED make all colors, even red shades, look dull and dreary compared to a 4000°K CRI 95.
If you want vivid colors and don’t have an SST-20 4000°K CRI 95 flashlight yet, you should consider this option long before any XP-L HI CRI 70 flashlight whatever its CCT.
Thanks, TK. My apologies for the stupid question — later I realized the answer was so obvious, because some people requested more than one. Thanks again for the list consolidation effort.
Excellent! :+1: Just another sign of how this flashlight design was well thought out.
And then someone PM’s me triggering an email I didn’t have the opportunity to fully read until now and I assumed that was the code and we were both wrong.
2 hours on start time and 25 on position. So it’s looking more like 4/27/2019 18:39. [shrug]. The PM with the code shows up when it shows up then the light ships when it ships.
