we adjust the appearance of TC66C, make it easier to understand how to put the switch(power supply switch and PD switch)
“Power supply switch button. When on, you can use system power supply; when off, you can use isolated power supply. For high precision and lower voltage measurement, you can switch to OFF and use micro port to power on.
PD Switch, place the switch on ”OFF” when measuring a device which is charging, PD function OFF; and place the switch on “ON” when do decoy trigger operation, PD function ON. Switch stroke is short so use the switch gently to avoid damage please.”
Actually, there are many review videos on YouTube, made by different people from different countries. You guys can have a look at these video. If you have interest, you can make orders.Thank you.
Recently, we have received many reviews about TC66C, you guys can have a look:
“And so, what can I say about this tester, as well as comparing it with ZY1276.
A big step forward is the application of the correct circuitry, the manufacturer finally decided to use an external ADC.
In addition, now there is a function not only of monitoring the charger control protocols, but also the ability to control the modes, and the manufacturer immediately waved to Power delivery.
In fact, this is in its simplified version of the ZY1276 tester, but simplified programmatically, not hardware. In favor of the TC66, I’ll take a more convenient firmware update, since a programmer is required for the ZY1276, as well as software, which has its own difficulties for the ZY1276.
The only thing that in my opinion is inconvenient is the presence of only USB Type-C connectors, in this respect the ZY1276 is more flexible as it has more familiar USB-A, but at the same time to connect the Type-C cable is required “dad” - “dad” Type -C, in fact, due to my lack of such a cable, I could not verify the management of Power delivery using ZY1276.
Otherwise, there were positive impressions, good accuracy, moderate functionality, availability of a stand-alone recorder, trigger mode, compact size, current measurements in both directions (with reservation), imputed price, availability of a version with Bluetooth.”
Hello,guys! Our new USB Tester is coming, its name is AT35, similar to AT34 but it has 5-digit resolution and higher measurement accuracy.
here is the video link of AT35:
1, as old rule, new products publishing have lowest price only 4 days, 9.8 usd/piece, if buy more 2 pcs, 8.8 usd/piece.
2. It is higher version of AT34. The important improvement is the voltage and current accuracy, now voltage and current are 5-digit, voltage resolution: 0.001V, current resolution: 0.0001A
