Oh man I’ve done this one before, but brain is failing me. Something like 1-4 vs 5-8, then one of those groups vs 9-12, then 1 and 2 vs 11 and 12 (those dependant on heavier/lighter).
Received coupon. Thank you!
Little drawback: 3$ more for standard shipping to Romania. But after all this waiting…
Ordered! :slight_smile:
I’d use my UV convoy s2+ to find the fake. Swallow the diamonds, beat the captors with the provided scale. I think that’s the right answer.
Thank you goshdogit, that would be them!! :+1:
I had a similar idea. Break them into three groups of four but then got confused about where to go after you compare the three groups against one another without running out of tries. Hmmmmmmm.
Yeah, not at my desk at the moment to work it out again, but I’ve definitely worked it out before in a repeatable fashion.
I do like the idea of the 365nm and violence though ;p
WARNING FOR RIDDLE ANSWER ATTEMPT
I’m pretty sure this works, but I’m tired so I may have missed something. It also doesn’t seem like the most efficient solution, which is worrying.
-Scale 1—————Scale 2———-Aside
1,2,3,4,5,———–7,8,9,10,12——6,11,13
1,3,7,9,11———–2,4,6,8,10——–5,12,13
1,2,7,8—————3,4,9,10———–13
This should result in the following mapping, where L: left side is light, R: right side is light, and B: the two are perfectly balanced (as all things should be).
1 LLL
2 LRL
3 LLR
4 LRR
5 LBB
6 BRB
7 RLL
8 RRL
9 RLR
10 RRR
11 BLB
12 RBB
13 BBB
I’m interested in ordering one if it’s not too late. Thanks!
You’re definitely on the right track… but it looks like you’re assuming the fake is lighter than the others. What if it’s heavier? This test can’t distinguish between #1 being lighter and #10 being heavier.
PM received.
Thanks TK and everyone who made this dream come true.
PM received, 3D model ordered. I was #1336 on the msg list.
I suppose it would have been wise to read the specifications a bit more carefully. I think I removed all the symmetric cases, although it still feels like I’m missing something. It worries me that I did not use the dummy stone.
-Scale 1———Scale 2———Aside
1,2,3,5——–6,7,8,11——–4,9,10,12,13
1,2,5,6——–3,4,9,10——–7,8,11,12,13
1,3,8,10——2,7,9,12——–4,5,6,11,13
1 LLL
2 LLR
3 LRL
4 BRB
5 LLB
6 RLB
7 RBR
8 RBL
9 BRR
10 BRL
11 RBB
12 BBR
13 BBB
I’m down for 2.
In for 1. Thanks
3D version will start to ship today
Thanks much to all who helped get this going. Especially TK. I did purchase 2 but would like to get in on the 2nd round of different LEDs. I would like to be able to purchase 2 more at the discounted rate when those come in. I am not exactly sure how that is going to work but if it means I am to comment again then consider this to be the post. Good luck all!
Thank you for this update Neal as well as the others you have given. :+1:
Thank you also for what you have done to make the FW3A a reality!!
Best regards…… :slight_smile:
it was posted several times, that the same code will work for the upcoming led variations ;)
if something changes Neal will post that.
I’m #1387 on the list, just got PM, so that’s where it’s up to (for everyone’s info)
Can I be put down for 1? Hopefully I’m not too late!
