Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
2245 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 3 hours 42 min ago
BlueSwordM wrote:
Yes.
Just rotate the cells on every charge cycle for equal wear.
There is no need for this. You are thinking the cell closest to the head gets warmer?
Once you recharge the cells you put them back in randomly, right?
JasonWW
JasonWW's picture
Scallywag wrote:
My SP70 seems to heat slower on turbo than my L6. I also can’t really visually tell when/if it steps down.
Stock or modded L6? The SP70 was designed to heat up slower due to the extra mass.
The amps seem to drop slowly as it gets really hot. I don’t think it does a sudden drop. I need to do more testing.
BlueSwordM
BlueSwordM's picture
Last seen: 5 days 20 hours ago
Yes.
In a series setup, the cell closest to the head generation will get slightly hotter.
Swapping the cells when putting them back in can help with small capacity degradation.
Ragsy
Ragsy's picture
Last seen: 16 hours 17 min ago
Thanks for the clarification guys!
G'day mate, ow ya garn?
Yeah, nah good mate
Scallywag
Scallywag's picture
Last seen: 3 days 11 hours ago
In my sig, fet+1 and XHP70.2
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
JasonWW
JasonWW's picture
I can confirm that the stock SP70 reflector is indeed lightly OP as stated by Sofirn. The L6 OP reflector is noticeably more bumpy. It can be really hard to tell from a picture, but I think I captured it in this photo.
I also noticed that the SMO reflector was 71mm across its inner diameter while the lightly OP is 74mm 75mm across its inner diameter. So the SMO is slightly smaller than necessary.
Using the Sofirn HD 25A cells I found the candela very similar between these two reflectors.
SMO – 192kcd – 876 meters
Light OP – 188kcd – 867 meters
Maybe there is room for improvement in the SMO by making it 74mm and maybe change the height or parabolic shape. I got the same purple dot in the center of the hotspot. I haven’t had time to play with reflector height, yet.
Between these two specific reflectors, Sofirn definitely made the right choice. The lightly OP beam looks great and is still pretty tightly focused. At a distance, the hot spot looks the same as my SMO L6.
The most distance I’ve got out of my L6 with SMO and 19 amps is 830 meters, the SP70 with OP and only 12.3 amps is already beating it.
Here are the new HD 25A battery labels. I wish they looked more different compared to the older 26650 black cells. Maybe a different color.
They performed almost as good as my black Liitokala 5000mah. The Aspire 4300 still has the highest amps. I tested them in my L6 at 5 seconds and at 30 seconds.
Black Liitokala – 16.8A, 16.1A
Aspire 4300 – 19.1A, 18.2A
Sofirn HD 25A – 15.5A, 14.5
So not bad. I still need to do capacity tests.
In testing the current in the SP70 I used Black Liitokala 5000, Aspire 4300 and the Sofirn HD 25A.
I measured at 5 seconds and 30 seconds with a short led cool down in between.
Liitokala – 11.9A, 11.5A
Aspire – 13.0A, 11.5A
Sofirn – 12.3A, 10.8A
So it’s not pulling the big amps like my Lexel built FET driven L6, but it’s still a lot.
I can also see the amps start to steadily decline as the temperatures get hotter. That 10.8 reading would probably be a little higher if the light weren’t so hot due to previous tests.
DB Custom
DB Custom's picture
Last seen: 3 weeks 6 days ago
Jason, something is awry…
cncyana
Last seen: 6 days 2 hours ago
Jason,
Thank you for the info. It’s looking like the light and HD batteries are a really good deal. I’m feeling a lot better about Sofirn’s reflector choice too.
Life’s Questions/Answers here: http://www.answersingenesis.org/home/area/qa.asp “So then, each of us will give an account of himself to God.” Romans 14:12
cncyana
Your reflector does appear rougher. Maybe if you duplicate Jason’s photo angle and distance since your photo is quite a bit closer? Who knows…
JasonWW
JasonWW's picture
Nope, from that angle, my reflector looks identical to your picture.
DB Custom
DB Custom's picture
Right, not a light orange peel. And while it does indeed work pretty nicely, it is certainly not the smooth mirror finish they promised in the OP. And the 70.2 doesn’t need any at all, unlike the 70 that came in the L6. I have modified quite a few L6’s with smooth reflectors and upgraded 70.2’s and they are very well received. Even the L2 with smooth reflector and 70.2 is an outstanding thrower with nicely focused beam. So that’s the one thing I wish they’d done here, given us the smooth reflector they said they were going to.
I have the light, it works nicely, but due to this one factor it’s not the light they said they were going to build. It’s really that simple. No orange peel needed. Certainly not this thick heavy OP they’re passing off as light….
Original Post, number one, as stated by Sofirn….
  • UPFDATE 08/14/2018 *
Once again to confirm other information. It’s much appreciated if anyone could help optimize for better reading.
1. size: 9cm big head, aluminum bezel
2. Smooth reflector, AR coated lens
3. LED: one XHP70.2, 5350-5700K emitter
4. 2*26650 long tube(sleeve for 21700),
5. tactical ring
6. Switch: tail forward clicky switch + side switch (with indicator as Q8)
7. Overheating Protection. Low Voltage Protection.
We got neither the AR coated lens nor the smooth reflector. A 74mm reflector opening is a HUGE difference from the quoted 90mm head. So there it is. It is a nice light, but it should have been a Great light.
JasonWW
JasonWW's picture
I think you’ve completely missed several points. I don’t have time to correct all of them.
Scallywag
Scallywag's picture
I'm actually a big fan of the light, except for the driver/ui. I like my OP reflectors on my 70.2s.
What's strange to me is the SP70 drawing so much less power on turbo.
Has someone gotten the driver out yet? I'm still considering returning it and waiting for the blf special edition, so I don't want to open mine up.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 hours 35 min ago
Hi there,
Sofirn asked me to help posting this information.
SP70 is now available on Amazon DE. You can get it for a discounted promotion price from April 28 through May 6, 2019.
SP70 flashlight only: € 50,00
SP70 kit-version: € 65,99
Link: https://www.amazon.de/Sofirn-Taschenlampe-XHP70-2-Helligkeitsstufe-Aktiv...
How to get the code:
Please ask for your individual code via e-mail to eu@sofirnlight.com or send a PM to Sofirn on BLF.
Note:
1. One unit per order.
2. One order per customer.
3. The promotion will end once the target quantity is reached, the deadline has passed or the stock is depleted.
Hallo zusammen,
Sofirn bat mich, dabei zu helfen, diese Information zu posten.
die SP70 ist jetzt auch auf Amazon DE verfügbar. Ihr bekommt diese im Zeitraum vom 28. April bis 6. Mai 2019 zu einem rabattierten Promotion-Preis.
SP70 (nur die Taschenlampe): € 50,00
SP70 Kit-Version: € 65,99
Wie erhält man den Code?
Bitte erfragt euren persönlichen Code via E-Mail an eu@sofirnlight.com oder sendet eine Privatnachricht an den BLF-Account von Sofirn.
Hinweis:
1. Nur ein Artikel pro Bestellung.
2. Nur eine Bestellung pro Kunde.
3. Die Promotion endet sobald die maximale Menge erreicht, die Frist abgelaufen oder der Lagerbestand aufgebraucht ist.
JasonWW
JasonWW's picture
Scallywag wrote:
What’s strange to me is the SP70 drawing so much less power on turbo.
Has someone gotten the driver out yet? I’m still considering returning it and waiting for the blf special edition, so I don’t want to open mine up.
It’s not strange to me. Most all factory FET drivers seem to perform a bit less than BLF drivers. Lexel, Tom E and Texas_Ace, etc… know how to extract the most power. They also use the best components which may not be available in China.
As far as why the SP70 driver is not pulling the same high amps as my L6, who knows. It might be related to the FET it uses or maybe there is extra resistance in the springs. 12A to 13A is nothing to sneeze at and it gets hot pretty quick.
I might swap the FET out with one from MTN E and see what effect it has. Maybe, I don’t know yet.
As for driver pics, Tom E just posted some. Maybe you missed it.
http://budgetlightforum.com/comment/1491552#comment-1491552
DB Custom
DB Custom's picture
I haven’t missed anything Jason, I know very well what the target was and what we were promised. The only thing I don’t get is why you yourself are so set on glossing over the glaring deficiencies.
You can’t build a light to throw and then scrap the reflector based on white wall shots up close. Glaring rookie mistake. The further it can throw the more a dark spot will show on the wall at close range, that dark spot won’t focus out for at least 10-15’ if the light has really good throw potential coming from a big die like this.
Simple facts learned the hard way, by building hundreds and hundreds of lights.
Please don’t waste any of your time responding, I’d rather you go build something…
CandleCat
Last seen: 1 year 2 weeks ago
How does this light compare to Acebeam T27?
JasonWW
JasonWW's picture
I think, you think, it was built based on the Kronos K70 targets. It was not. This is probably the source of your confusion.
Hang on, you didn’t even read what I said. Plus you also make assumptions about the distance.
For the record, one more time, this light was not built for maximum throw. If it was, we would have put an xhp35 hi in it. This is basically designed to be a factory hot rod version of the S70/L6. Higher output, better UI, more throw (not maximum) all from the factory, no modding necessary. Plus at an affordable price. We have met all these goals.
Lux-Perpetua
Jason, Dale...I don't mean to interrupt the little disagreement of yours but maybe we all can acknowledge and agree that the SP70 is Sofirn's first (successful) attempt to build a big XHP70.2 light. Thus, their experience might evolve in time when they develop the BLF edition that hopefully fulfills all of our highest expectations such as a big leap in terms of throw and more efficient components (e.g. Infineon FET, SMO reflector, dedomed XHP70.2, BeCu springs, AR coated glass, and so on...). I could also imagine Lexel to invent a nice buckdriver for the SP70 for a more regulated output. Personally, I was in hope Sofirn would have spent more time for testing the SMO reflector and the optimum alignment of the emitter to reduce tint shift and rings in the spill. Maybe this can be done with the BLF edition. For the discounted price of $ 50 or € 50 it's still a very decent result we now get to buy.
WTF
Last seen: 13 hours 54 min ago
Barry0892 wrote:
Guess it’s time to talk about a BLF version. maybe: retaining ring, smooth reflector, different tint, no switch tail cap, Anduril firmware? Big Smile
It looks like everyone missed post 2000.
Scallywag
Scallywag's picture
I'd love to see anduril or narsilm on this.
Jason, thanks. I thought I remembered seeing some, but didn't know if I was getting it confused with other lights. Nice to see the switch is a separate pcb, and not attached to the driver as some lights do. Would be easy enough to swap something Lexel builds into it.
Also, for the led color temperature, the Cree Fried Egg™ is strong enough in the corona that I don't notice how cool the cct is unless I'm really paying attention to the spill.
djozz
djozz's picture
Last seen: 1 hour 21 min ago
These 2 remarks, made right next to each other, sound conflicting to me.
How can you tell that Sofirn made the right choice of reflector if you did not check yet if they did the focussing right on the smooth reflector, especially if both you and Sofirn found a hole in the center of the beam while we know here on BLF that the XHP70.2 makes a fine hotspot in a smooth reflector.
I do not think that a non-parabolic reflector can be a reason, never heard of any manufacturer making non-parabolic reflectors, there is no reason to do that other than screwing up CNC settings.
This is in no way an attempt to dismiss Sofirn’s first big thrower, I think that the SP70 does many things right, and the good price more than makes up for the shortcomings that it still has (finning could be more effective, reflector deeper and smooth, a real BLF-UI would be more attractive).
Tom E
Tom E's picture
Last seen: 1 min 22 sec ago
I know I posted these earlier, somewhere:
Oops, here, post #1957, and more info: http://budgetlightforum.com/comment/1491552#comment-1491552
Scallywag
Scallywag's picture
[pictures snipped]
Yes, Jason also linked it. Thank you both.
JasonWW wrote:
[ It's not strange to me. Most all factory FET drivers seem to perform a bit less than BLF drivers. Lexel, Tom E and Texas_Ace, etc... know how to extract the most power. They also use the best components which may not be available in China. As far as why the SP70 driver is not pulling the same high amps as my L6, who knows. It might be related to the FET it uses or maybe there is extra resistance in the springs. 12A to 13A is nothing to sneeze at and it gets hot pretty quick. I might swap the FET out with one from MTN E and see what effect it has.
I forgot to reply to this part. Yes, 12A is nothing to sneeze at, and we're looking at something like 90 watts there. Although I'd disagree that it heats quickly. Between the power reduction of possibly up to 50% as well as what we're hoping to be better thermal mass, my SP70 is not a hand warmer like my L6 is.
I'm really excited to see your efforts with a new FET and Tom's efforts with an ATTiny. I just need to decide if I want to mod it, or if I trust Sofirn enough to get the BLF edition right. Well, not even right, because many would probably prefer slightly different features than me.
Other notes:
I just noticed the tactical ring thing by the tail spins freely. Weird!
My dual springs appear to be compressed enough to both make contact with Shockli 5500mAh button-tops.
BlueSwordM
@Scallywag, can you check if the springs are magnetic?
Thank you.
JasonWW
JasonWW's picture
The tactical ring is not threaded, it’s held in place by sitting on o-rings.
JasonWW
JasonWW's picture
The way Sofirn explained it to me was that they could not play with the reflector height because the centering rings had already been made and having a new batch made would have created a big delay. So they had to chose an ugly beam or a pretty beam.
If adjusting the reflector height makes for a nice looking hot spot, then Sofirn probably has the time to have new centering rings made. I also hope they can make the SMO reflector the full 75 millimeter inner diameter. There needs to be a noticeable jump in distance between the two or what’s the point of the SMO.
I can actually think of a reason to use a non parabolic reflector shape. Since the parabola is based on a single point source, I can see were a really large emitter like the 70.2 might cause some anomolies. I’ll use the picture below.
Notice how a large emitter could potentially create anomolies in the hot spot? A very slight alteration in the reflector shape might eliminate the anomaly. If it does, why not incorporate that tweak to the shape?
Or maybe a parabola is fine, but this particular one is not focused properly? IDK.
My Lumintop Tool AA also has a colored spot in the center of the hot spot, but it’s yellow instead of purple.
Certain things are really strange to me. Like why is the SP70 SMO spot purple? Where is that color coming from? It’s beyond my understanding.
djozz
djozz's picture
That the led is not a point source does produce imperfect imaging, but that does not make a difference, the parabola will still be the best shape for producing throw. No magic possible here.
I do hope that Sofirn can sort out the smooth reflector, indeed full size and well-focused.
Yourrid
Yourrid's picture
Last seen: 19 hours 40 min ago
My 2 cents, for what it’s worth (probably less than 2 cents Silly )
I, for one, greatly appreciate Jason’s efforts in bringing a new light to market, that performs pretty darn well. Let’s be honest, anyone on Amazon that is not a flashlight enthusiast is going to be blown away by the performance. As well as many of our fellow constituents who already enjoy the light.
What I dislike is the manufacturer’s willingness to push a product onto the market before it’s perfected. We keep seeing this with other manufacturers where a design is made, a few prototypes are sent out, and before the prototypes get in the hands of enthusiasts, its already on Amazon (or pretty darn close.) Astrolux and Amutorch just did a similar thing of having a group buy before the lights were even made! I think Sofrin jumped the gun on this one. While it’s a great flashlight, it could have been a fantastic light with a little more tweaking (reflector design while using the same head, better UI, higher quality driver components)
Sofrin, I will not be buying a light until I see a dedicated BLF edition which remedies the reflector design, and utilizes a better user interface. Single click ON to the last setting used (which is usually high) is a huge factor. I would be willing to pay a premium price to get the light I (we) like.
Hopefully we can keep the conversation going, constructively and objectively, because I would love to see a light that really achieves the objectives which were originally set forth.
JasonWW
JasonWW's picture
Just to be clear, it does do this. (In case you thought it didn’t and needed to be added)
