TLF/BLF/Lumintop FW3A review (18650, 3x XP-L HI cool white)
I hope it hasn’t come across as being too argumentative. All I’ve really been doing is asking why the tube and springs shouldn’t have been made a small increment longer to guarantee that both common styles of unprotected high-drain cells would work. Like the Emisar flashlights, for example.
I know the design is finalized. I have my order code. At this point, I’m just bantering with folks who keep explaining to me why they considered accommodating both battery styles to be such a bad idea two years ago, LOL!
Yeah but still
Supporting button tops is a poor choice because they shouldn’t exist in the first place IMHO. Only AA/14500 and AAA/10440 lights should support both due to the disposable and NiMH cells being exclusively button top.
All e-cigs I know of really only support flat tops and any commonality between that HUGE market and flashlights is a win for li-ion flashlights.
I’m not sure I understand you, but the FW3A does support flat top and button top. Are you thinking it doesn’t?
They did think of it. They incorporated it into the design, and it works. The FW3A can use flat-top or button-top cells, as long as they don’t have a protection circuit added.
Button-top cells work in:
  • Proto1
  • Proto2
  • Production lights (proto5)
Button-top cells don’t work in:
  • Proto4
… and the status of proto3 is unknown, because everyone who received one disappeared before reporting results.
The proto4 lights didn’t work with button-top cells because of a manufacturing error which put the driver in the wrong place. It was the reason why proto4 wasn’t approved for production… but it has been fixed.
Hopefully there won’t be any more uncertainty about it.
It’s been repeated several times that 66 mm would be the absolute maximum length, even after the driver-fit issue was resolved. I believe this was again reported after the last prototype evaluation.
But I sincerely hope you are correct, and longer button-top cells such as my 30Qs (66.8 mm) and VTC4s (66.6 mm) are accommodated without risk of denting.
I’m buying anyway, of course.
But they do exist, in great quantity. And they are the recommended fodder for some lights, such as Emisar.
Many of us have quite an assortment of batteries on hand, and it’s a win-win to have flashlights that accept both.
I’m not sure if you saw my first answer, but it was about a page ago:
Lights that accept button-tops - really those that prefer them - are the cause, not the effect. The sooner that incentive to manufacture them disappears and li-ion cells are as standardized as other batteries (as they should be since the entire naming scheme for them is based on their size) the better.
I get that it sucks for people that have mostly have button-tops but the standards change for tech way faster than they have for flashlights in just about every other industry. Thankfully we don’t have to measure USB, HDMI, etc. cables before using them for anything.
And it’s good that the USB 3.0 ports on my computer also read and write USB 2.0 devices. I have quite a few of those around. Compatibility is a good thing.
And may I say funkychateau, you are doing a masterful job of that; in both this & the main FW3A thread too I might add. Reviving the discussion every month or two & dissappearing for a while after the lively debates.
Masterful my friend… masterful. :+1: . :beer:But… :person_facepalming:
:slight_smile:
I’d argue that that backward compatibility shows the opposite: there was a clearly defined physical standard, not the original USB port dimensions and also a slightly different one that was hacked together for no reason, creating the actual compatibility issues.
If a light can use both that’s cool, but button tops in general are a problem looking for a solution.
Just remove the button top. It’s easy.
I have some protected button tops that I should not have ordered. I’m also quite new to all of this. Can you point me to an article or video that gives instructions on how to change these to unprotected flat tops?
I’m also interested in this if it can be done right and safe. I tought it was impossible to do so because they are spotwelded. But I m known to be wrong on occasions
:smiley: …. Me too…. :+1: . :wink:
It really isn’t safe for someone without a LOT of Li-ion experience to try and remove a spot welded button top. Very easy to short out the cell and that can be bad. The safe option is to get new flat top cells for the devices that use them and use the button tops in lights that require them, like the D18, Meteor, Q8, and so on…
That is the correct advice.
But, it’s pretty easy to remove the button, which is just spot-welded with a nickle strip to the positive terminal of the “real” flat-top unprotected cell. As long as the wrap and insulation ring is protecting the cell from shorting, then just take a pair of pliers and rip off the nickle strip. That will leave some bumps on the battery from the spot-weld. Take a dremel tool, and very gently sand them away. Done.
Of course, my advice is not to do that, unless you’re very sure of what you’re doing. At the very least, keep a bucket of water nearby to throw the cell in if things go wrong. And then run so you don’t breath any of the very toxic fumes from a lithium-ion fire.
Not all are done that way, some are literally spot welded in three places around the outer edge of the button. Those are much more difficult to remove if you don’t know what you’re doing. :wink:
Uh, totally wrong advice to throw a li-ion cell in a bucket of water! Lithium reacts with water and burns! No NO No!
