FW3A Troubleshooting / FAQ
strange the bottom AMCs are not optimized for cooling effctiveness
and MCU pin 7 going over a resistor and cap to LED-?
Maukka discovered it and told me about it. I had a fix tested and committed to the repository 20 minutes later. So it was fixed quickly and easily… but not until after the first drivers had been produced. It’s not a big deal though, just a minor inconvenience for one specific UI flow.
It can’t connect the 7135’s big thermal pin directly to the outer ground ring like usual because it has a switch contact ring in the way. Driver layout was a little weird with the switch ring there.
As it says in the layout file, that’s the optic nerve. It can see. I did a video about it two years ago, around the time the FW3A project was starting, and it ended up being included in this driver design. But after looking into it more, it turns out to not be very practical so I didn’t make use of it in the FW3A firmware. It’s still there for anyone who wants to try it though. I’d still like to do more development with it sometime, but it hasn’t been a priority.
I completely missed this programming interface, even though it is rudimentary or not enable right now. This is some next-level gadgetry you guys built!
Yeah, sorry. I forgot to have Neal list that on the product page, but there’s a hidden feature: It watches you while you sleep! :stuck_out_tongue:
Watching me while I sleep? So this light can replace my girlfriend? Awesome :smiley:
j/K
this reminds me of the Lux-RC setup Lux-RC Labs - NXS - NXS Designer - Create New
hope it stays quite here ;)
Is it too early to ask for a FW3A v2 thread?
FW3A v2 could include charger and optical programming interface. More tints and also more LED choices.
(I will run and hide somewhere so I won’t get stoned)
:open_mouth:
I think the dev process was rock-solid on this one and the thread will remain largely empty. IMO, nothing went wrong at all.
Don’t worry, Astrolux will make a crappy knockoff with integrated charging in a year like they did with the D4.
If there was a single LED optic that would fit, and allow more Aux LED’S that would be perfect for this light, IMO. I’d really love to see a focus on adding more Aux LED’s and different channels for different colors. Then we’d be able to have all kinds of funky modes that my daughter and I could have fun with.
different channels still suffers on the 8 leg MCUs BLF firmwares using and firmware code not support such fancy things
Please explain.
D4 —> S42
Those lights came out at the same time, not a year apart. This means they are unrelated. No one copied anything. It’s just two somewhat similar lights coming out at about the same time.
I know this has been covered, so if you have any threads that you could suggest, that would be appreciated. Two legs are for power, and the 6 free legs are used for? Is the biggest hurdle in using some of the newer MCU’s just designing and building drivers? I understand that we don’t have firmware for them, but from what I gather it’s fairly easy to port the Attiny85 firmware.
2 legs power
1 leg unuseable reset pin
1 pin voltage divider
1 pin switch
1 pin switch LED
2 pins for FET+AMC
usually
new MCUs like the 1634 got like a dozen pins that can be used when you already have power and reset connected
just so far no BLF firmware runs on them so you can add fancy stuff like color fading aux board or stuff
Thank you Lexel, so if we gave up the ability to reflash (easily) we could gain another pin to use by getting rid of the reset fuse. But, not practical for mass production, and not much memory left on the Attiny85 with Anduril to utilize said pin.
I worked in a remote bush camp many years ago where the rule was, anyone who complained about the food immediately became the cook.
In my opinion, this flashlight is flawless! :smiley:
There isn’t currently anywhere to attach an aux LED board in the FW3A, unless it was on all the time with no ability for the user to control the aux LEDs. Here’s the MCU pin layout:
/* BLF/TLF FW3A driver layout
 *   Reset -|1  8|- VCC
 * eswitch -|2  7|- optic nerve
 *     FET -|3  6|- 7x7135
 *     GND -|4  5|- 1x7135
However, if you cut pin 7, it could be used for this purpose. Basically remove the capacitor and resistor it’s attached to, put on a different resistor (optional), and attach it to an aux LED board instead. Flash new firmware with support for aux LEDs, and it should work.
Discovered an issue today:
Several times now after inserting the battery at the head and then screwing closed the light I’ve noted that the head sometimes stops screwing down a couple mm before it should. This appears to be caused by the inner switch contact tube being slightly off-center and hitting the edges of the narrow driver retaining ring. When this happens the inner tube does not make contact with the driver and the light does not work.
If this occurs, the light can still be screwed down by unscrewing and then rescrewing the head in several times until things line up right. But that doesn’t solve the problem and is frustrating to do. This issue occurred with both my FW3As.
Analysis and Solution:
The problem appears to be caused by the driver retaining ring not being screwed tight to the driver at the factory. If you encounter this issue, use tweezers to turn the driver retaining ring so that it is flush against the driver. Once the retaining ring is snug, this problem goes away completely.
Whew, that’s a relief. I think even my feeble modding skills can handle that.
