TLF/BLF/Lumintop FW3A review (18650, 3x XP-L HI cool white)
Uh, totally wrong advice to throw a li-ion cell in a bucket of water! Lithium reacts with water and burns! No NO No!
I don’t have any links, sorry. If you are good with tools it should not be too hard.
First, you have to understand that the positive and negative part of the battery are very close, so caution has to be used to not touch both at the same time with anything metal. If you do, you might get a spark. No big deal, but try to avoid that. Discharging the battery to 3v or so also improves safety.
In the picture below, the positive is the red part and the negative is everything dark gray, the vast majority of the exterior. There is only the gold layer (plastic insulator) that keeps them seperate.
Button tops are stacked onto the red piece. Sometimes they are spot welded, sometimes not. Sometimes they have a longer metal strip underneath that is spot welded on each end. There are a lot of variations.
Here is a 30Q with a button top spot welded in place. It had a clear wrapper covering the stock pink wrapper. I cut away the clear wrapper and used a small screwdriver to pry the button top off.
I did not need to add a new wrapper, but I do keep some handy.
Here is a different 30Q that I removed the button from that had the metal strip under it. I cut it’s clear wrapper off, lifted the button top and then used pliers to carefully pull the spot welded strap off the battery. You might need to used a small grinder or Dremel to get rid of any burrs from the spot welds.
You might want to practice on a junk button top battery just to get an understanding of it’s construction before trying it on a good battery. Always be careful to not cause a short circuit. You also might want to use an extra piece of insulating plastic to put over the edge of the cell to make it easier to pry the button top off.
LOL Teacher, I can handle a little sarcastic jab. But it does seem that I keep responding to the same notions over and over, from new folks that haven’t read previous posts. And if I disappear for a few days, or even a week, it’s not part of a plan. I just have a pretty busy life offline. I retired four years ago, and I’m still waiting for the “leisure” part to kick in.
However, this notion that we should never accommodate button tops because doing so encourages a bastard battery configuration that “shouldn’t even exist” (because the e-cig community doesn’t use them) is a new angle …
It’s my understanding that there is no lithium metal in lithium-ion cells. So, it shouldn’t react with water. Well, that’s my understanding, but I’ve never tried it.
Lithium primary cells do contain lithium metal, so I could see how those might react.
And responding quite well I might add funkychateau. If you are not an attorney… I think you could be. And probably a darn good one too…. :smiley: … :+1:
Heck, I do not ever use buttontops unless a light absolutely requires them ; but your ‘arguments’ (reasons) even got me to thinking for a bit. Then I shook off your mesmerizing & got back on track. :smiley:
Good reading for sure my friend….
Take care…. :beer:
Not my discussion so excuse the interruption, and I am not a chemist by trade, but I wouldn’t be taking that chance either. Elemental lithium is highly reactive, like you said, but many lithium-ions are too. My recollection from Chem1212, which granted was a long time ago, is that the lithium ions are going to react with the water pretty quickly, resulting in some sort of lithium oxide while releasing lots of hydrogen gas. This would be highly exothermic too, so lots of heat. Hydrogen gas + heat = bad news.
Besides that, I think the original premise here was that a bucket of water could be used to “put out” or otherwise contain a runaway li-ion cell, and that’s a faulty position from the outset. You won’t be stopping that internal lithium reaction with water. Its not going to stop until its out fuel/energy. So even if the water doesn’t make it worse (which I’m not convinced is true), its not really going to help either. You’ll still have a runaway li-ion cell on your hands…just now its wet.
So please, anyone who comes along reading this and decides to take some side cutters and a dremel to their stack of 18650s for any reason, do it outside. Away from everything you value. Because if something goes wrong you really only have one recourse — run away and let it burn itself out. A dead brown spot in the lawn is going to be best case here, I think.
Oops, I was thinking of removing just button tops. It’s a little more complicated removing protection circuits. Some circuits are on the positive end and some are on the negative/bottom end
For these types of cells you might need new wrappers and a heat gun/hair dryer.
You first have to carefully remove the outer wrapper. Be cautious around that metal strip running up the side.
Once I removed all of the extra circuitry and deburred any areas that were sticking out or sharp, I added a new wrapper to it.
I’m with DB Custom, emarkd, & whoever else. If ’your’ not very confident you can do this properly…… DO NOT do it.
Spend $5 & buy yourself a flat top 30Q. :+1:
Could be. But, if the battery is already on fire, it’s burning already.
No, I never meant to imply that. Lithium-ion cells contain their own oxidizer, so they don’t need oxygen to burn. Throwing it in a bucket of water hopefully contains the fire, and will help cool the cell. The latter being important if it’s just getting very very hot and hasn’t caught fire yet.
Anyway, don’t mess with cells if you’re not smart about it. But let’s not overstate the risk. The only way you’re going to cause a fire is if you puncture the cell. An accidental 1-second short isn’t going to do it.
This. All day.
It’s just not worth messing around.
Remember the times when the Airlines would not deliver Li-ion cells? Because of fires on planes? This was because of the vape folks ordering liquid’s for their vape unit and Li-ion cells together… when packaged poorly the containers of liquid got broken and the wet Li-ion cells combusted… in the cargo hold of the airplane. Wet Li-ion cells are just bad news. period.
Don’t teach people HOW to mangle a potentially lethal cell, teach them NOT to.
Or be sure your bank account is padded so when they screw up and sue you for the damages you can handle it. :wink:
Thanks everybody for the information on how to do it and why it’s best for me, that I shouldn’t do it.
Lawyering might be fun, but difficult to handle being the butt of so many bad jokes.
I used to be a professional nerd, running the Semiconductor Modeling Team and the Engineering Lab for a GaAs/GaN wafer fab and design facility in Dallas. But since 2015 I’m just another retired guy waiting for leisure time to kick in.
I think sleeping on a bed of $100 bills would make the jokes tolerable
Another word of caution about attempting to modify li-ion cells: The power output of these cells is high enough to cause second-degree burns in the split second it takes to jerk one’s hand away.
Unfortunately, I know this from personal experience.
I haven’t had a single button-top cell that was welded, but that might depend on your source I guess.
So the lumen output of the cool white XP-L HI is 2800. Can anyone comment on the likely output of the 7A (3000K) XP-L HI?
Very likely it will be less. How much less, I don’t know.
IIRC, the Convoy C8 was listed as somewhere around 20% less for the 7A vs the 1A. I can’t find the specs on that right now, so I’m going from memory.
I bought the 3A and 7A, and visually there’s not much difference.
I think your right about the source.
I have quite a few from Li Ion Wholesale & all are very securely & nicely spot welded. They do it themselves, ‘in house’; and do it right.
I have several from China vendors & about half of them are spot welded. Most of those spotwelds are pretty crappy to…. especially compared to LiIon Wholesale.
My experience…. yours may vary. :+1:
