[quote=ToyKeeper]
[quote=pinkpanda3310]
[quote=ToyKeeper
I’ll run this through my test script to check it. Even if the script reports failed cases, it looks pretty close. I expect there should be at least one solution which can identify the fake but can’t determine whether it’s lighter or heavier… but at a glance, I’m not totally sure if you’ve found such a thing or not.[/quote]
I thought the specification said we only needed to identify the coin, not necessarily determine light or heavy. The only stone which I could identify as the misfit but not classify as light or heavy would be 13 since I never weighed it. I could fix that and then I’d need to use the dummy weight.
