That is certainly another good idea. The other way to tell where the edge is to put the light on turbo/max this way we know that the other channel would not be discarded in the averaging. Blinking is welcomed
Sorry for the confusion, I don’t have a prototype on hand, just a picture from this message to test how the logo with exo2 font would look on it.
(Previous message edited).
Sorry to nitpick on the method: it helps integration quite a lot if you wrap as much as possible of the black parts of the lantern in alu-foil (but in a neat way using some cellotape so that the foil does not move too much across the measurements)
Its trickier for measuring 360-degree lanterns versus directional flashlights no doubt, but will be comparing it tot its self with globe/shade on versus off, as compared to the V1 & V2 tests i done.
Interested in one too, and it would be nice to have the option to order one of these fantastic looking lanterns with a case but without batteries: I have plenty of 18650’s already……
Did I mention I think it’s looking fantastic?
Regarding the logo choice I’m with Djozz, the other one has letters that are to thick for my liking.
No, I do mean relative numbers too. Even small black things inside integrating spheres affect the amount of integration noticably, and a huge black thing like the BLF Lantern inside a relatively small sphere will effectively kill useful integration of the light output. (no good integration means that what we measure is not total light output, and comparisons can only be made with light sources with the exact same beam. While a different beam is what you want to compare here) It will be a little better than just leaving the sphere out of the setup and just position a luxmeter next to the lantern, but not much better than that. Making the lantern shiny (or even better matt white) enormously improves integration so that your measurement actually somewhat represents total light output and so you can make comparisons. Btw, also baffling the detector against direct light from the lantern would make integration better.
It is not that I want to wish to come over as some know-all, but measuring light comes with some pretty annoying rules and in theory design decisions could be off because they are based on too rough comparisons, and that would be unfortunate.
