*BLF LT1 Lantern Project) (updated Nov,17,2020)
Maybe you need to change your user name to DS*BAR*.
I like to HELP people whenever I get the chance. If you need HELP at your bar I am willing to come over any time!
You know your project is on a roll when someone posts pictures of a “defective” lantern that has a “hole” in the beam and you immediately get several brand new forum members and LT1 additions! lol
I just talked to my neighbors about this and they go camping and have kids in boy scouts. They told me to order two more just for them. NO BRAINER!
This project has taken on a life of it’s own at this point. People get famous for doing less than this.
The lanterns charging circuit can use up to 15V input, so those regular 12V panels can charge it diretly with a USB-C cable
I was more intending on a 12 to 15 feet, not 5 meters. I have a 12 foot one now that i can plug into the V1 when its inside (a tent, camper, house, cabin, RV, etc. and run it outside to the 10 watt solar panel laid on a table or the roof, and it stays charged. for a 12 foot or 15 foot cable, it will need to be a heavier gauge wire. ( #22 or 24, liek the 12 foot one i bought at a local store that works fine.
Sing me up for 3 more, 4 in total
So in for 2 more?
Never mind….I put you in for another 2,
Yes! Sorry. Didn’t make that clear. 2 more. 3 total.
No. I wasn’t suggesting that an options with batteries was not needed.
I just didn’t want to have to get batteries in order to get accessories. (What I saw in the original post was the accessories and batteries were bundled. But perhaps I was reading too much into it.)
Triple down.
Meaning, I’m on the list at 978, please add me for TWO more (total of three).
I have two brothers. I should maybe add another, because I also have a father who might be interested, but let’s start with a total of three (from one).
You’re all doing great work.
I would also like to enter for 2 more.
As well as blammergeier I am already on the list for 1.
so in total: 3 for me please
Agreed :beer:
I like it :smiley:
Agreed, thank you very much :beer:
Hi, please put me on the list for one.
Thank you.
@DBSAR, 12-15ft is 4-5m, which is still extremely long, and you will be getting high power losses.
A max of 2-3m, or a max of 9ft, would be the best bet.
Please put me on the list for one.
Thank You.
I have done a quick test of the charging port
also 2. measurement I have overwritten the automatic protocol to charge at 12V to test the plug in to a 12V source as 1:1 car adapter or diretly on a 12V solar panel
Can this work with a 1x 18650?
Of cause, why not.
It has the same battery-tube as the Q8 and it do not need many amps from the battery, because it should have a long runtime.
yes, just expect 1/4 the run time compared to 4x18650
Ooooh, I completely missed the part about the charging circuit.
So it accepts up to 15V. Is it the TP5100 BlueSwordM mentioned earlier or something like it?
That would mean there’s no QC or USB PD or anything fancy like that?
If I understood correctly you can plug it in to a 5V USB power and it will take that but if you hook it up to a 12V solar panel it will happily accept that as well?
Hmm… How is the charging circuit integrated to the rest of the flashlight?
I’m just wondering if the lantern is moddable in that regard?
With previous talk about configurable charging rate my guess is it wouldn’t be?
DBSAR, regarding the cable. 12-15 feet is ~3.65-4.57m. Not that far off from 5m :innocent:
24AWG is pretty standard with decent quality charging cables.
But 20AWG is certainly doable with Type C and legacy Type C cables. I think I’ve even seen 18AWG at some point.
These just won’t be cheap so I’m not sure it would be worth it.
As if I did the math correctly, there’s 2.5x more copper in 20AWG than there is in 24AWG.
That’s a bit of a jump in terms of cost. And copper is expensive these days.
I’ll just dump some voltage drop values here for 5 meter cables with one pair of copper conductors
20AWG and 5V1.0A = 6.66% drop or 4.67V at the end
20AWG and 5V1.5A = 9.99% drop or 4.5V at the end
24AWG and 5V1.0A = 16.84% drop or 4.16V at the end
24AWG and 5V1.5A = 25.27% drop or 3.74V at the end
Even if we drop the length down to 3.5 meters it would still perform rather poorly in my opinion with
24AWG and 5V1.0A = 11.79% drop or 4.41V at the end
24AWG and 5V1.5A = 17.69% drop or 4.12V at the end
I’d say a 2 meter cable would be a good compromise
24AWG and 5V1.0A = 6.74% drop or 4.66V at the end
24AWG and 5V1.5A = 10.11% drop or 4.49V at the end
Or 2.5m. Something in that ball park.
good points. maybe shorten a good HD cable to 8 or 10 feet then.
