*BLF LT1 Lantern Project) (updated Nov,17,2020)
My summary of the lantern will be in this post
I have done a quick test of the charging port
also 2. measurement I have overwritten the automatic protocol to charge at 12V to test the plug in to a 12V source as 1:1 car adapter or diretly on a 12V solar panel
I will start now with precise measurements on the BLF lantern
first was that I could see visible brightness changes when doing tint ramping
now also the measurement shows me clearly that ithere is less brightness when between the tints
so there is some work for toykeeper to adjust the tint ramping code,
this was to be expected that some fine tuning is needed
some sort of switch breathing?
current through switch LED shows “heartbeat” pulsing
Thermal test
Setup
room Temperature about 20°C
Maximum current with 7 AMCs
this is a 15min test in timelapse reduced to one minute
the upper part heated up to 41.6°C
30min thermal images
temperature stays on absolutely safe level
permanent LED trimmer added and changed to my 2x2 LKED board with WW LEDs
Things that need to be changed on hardware side
- Programming key viases 0.05mm smaller diameter
- electrical reverse polarity protection of charging circuit and/or mechanical
- switch with warm white LEDs
- added permanent LEDs to switch
- switch wire colors changed to logical colors
black GND (atm LED)
white switch (atm GND)
red Ind. LED (atm switch)
another color for the permanent LEDs
5 millimeters is plenty of depth for most tripods and attachments i know of, sounds good.
Yep, it’s on the todo list.
I saw the same thing with the early tests a few months ago, but that was using old XM-L emitters… and those are known to have a slow response curve. So I was waiting for the real prototype before I try to adjust it.
Interested
Put me down for 2, please.
I do not want a breathing switch. Not too worried, though. I’m sure there will be a way to disable it.
This makes me happy. :slight_smile:
The stair-step pattern is the button’s blinking mode in standby. It loops through a 16-step pattern which looks a bit like a slow heartbeat.
FWIW, the button has 4 modes:
  • off
  • low
  • high
  • blinking
But what makes me happy is that there are no spikes in the flat zone in the middle of the graph. That means the power use is too low to show up on the scope. It wakes up 8 times per second, so it theoretically could have six spikes in that flat zone, but it doesn’t. So the cost of waking up is indistinguishable from zero.
What it actually does during those brief wakeups is send a “EV_sleep_tick” event through the UI code, which the UI can handle however it wants. In this case, it just updates the button brightness level. Then it goes back to sleep. But this could also be used to implement a timer for a sunrise or alarm clock mode, or to otherwise do things while it’s “off”.
Please put me on the list for two.
7 clicks unless the firmware has been changed for some reason.
Interested in one.
Thermal test
Setup
good to hear. :+1: Those are comparable temps i got from the V2 prototype before i resistored the driver back from 2.0 amps draw on maximum, mode after 15 minutes, i got a measured 58 degrees C at the top center of the lantern head with the four 4000K LH351C emitters, then at around 52 degrees with a amp load of 1.65 amps for same duration. ( though its likely this production sample will have better heat dissipation and tolerances for heat transfer from the LED MCPCB to the solid aluminum head.
Lexel, I pieced this post together with data from your post above. I know the test conditions may have been different, but I am guessing he max current you saw with the 7AMCs running was the 2.5A measurement from the video (from some tint ramping testing). Is this correct? Makes sense, 7x0.35A gets pretty close to 2.5A.
Those who don’t want such high levels can disconnect some of the 7135s, It looks like from a picture of the driver board I saw you could (if you wanted) reduce the number of 7135s to only 2. About 5 hours of run time at max with 7 7135s, and 20 hours with 2 7135s on max, assuming 4x3500mAhr batteries. Really looking forward to fooling with one of these when they go on sale. You put so many hooks in place one does not need to be a “modder” to make adjustments here.
Please put me in for a second one. Everything looks great so far!
Nice. It looks like it performs better than expected.
I thought the plan was to use 4 or 5 AMC7135 chips per channel, with solder pads available for the user to increase it up to 7 if they want. Is the plan to enable all 7 by default, or just 4 or 5?
So does your test mean the charging circuit accepts QC2.0 in input? Does it provides the same in ouptut?
Or does it only mean that your USBmeter think that anything above 5V is some QCtrickythin' ?
Does this light have a better physical reverse cell protection design than the Q8 v1 had? The Q8 just had a thick brass ring with out any raised plastic on either side of it to allow only a positive battery nipple to make contact.
This lantern with its safe low current and built in charger would make a great gift for a flashlight muggle. But that Q8 battery+ brass ring design would give me reservations gifting it to someone who might put in a battery backwards.
This prototype doesn’t have a RPP (reverse polarity protection) ring inside, but maybe the production model could. As long as it’s fairly easy to remove, it should be fine.
It is perhaps not something that you would like to do when you buy a new flashlight (unless you are a flashoholic/modder, in that case no light stays untouched for more than 15 minutes), but you could glue a plastic disc on the driver yourself, filling the space inside the brass ring, just a tiny bit protruding above it. That will take care of the reverse protection.
The MCU has reverse polarity protection, the charging circuit not
I guess to play it save adding a reverse polarity protection FET to the charge circuit on final driver revision would be no harm
