CUSTOM Emisar D18 builds are AVAILABLE!
The regular SST-20 5000K flavor is probably the best option for that.
That would be too easy…no mixing tints, no challenging Vf problem?
Any chance it’ll come with standby LEDs similar to the D4S?
I ordered a D18 with SST20 3000k and 4000k. I like both Colortemperatures, so i thought this might be really good.
the 4000k has a bit green on low levels? do you think mixing in 3000k will hide that greenish look?
I dont use my lights on very low levels though so i will not suffer to much, but still. :smiley:
Im not sure which layout Hank chose when installing the emitters, but i would guess its like TK’s layout, for maximum blending.
Thanks !
No, probably not.
Order another one with 3000K, 4000K, and 6500K. Now I have the perfect 4500K mixed!
No joke, you can PM Hank to ask. I also thought it would be more like 15-20$ less for a D18 without leds. But maybe it disturbs the manufacturing process somehow, who knows. :person_facepalming: It would just be easier and faster to solder leds to an empty MCPCB instead of having to remove the previous ones.
Thank you for the offer, contactcr, but I would just buy the normal D18 then. :wink: If you get 18 SST20 leds for 10$ it could even be worth the effort to remove the leds from the MCPCB and replace them with Luxeon V2’s.
Can you post some pictures of beamshots and close-ups when you receive it? What did you end up choosing for the layout of the 3 tint mix?
Oof.
That isn’t going to look all that good.
If only there was an SST-20 5000k 95CRI.
Would make things easier.
there is simply almost none room to make an Aux board, the conventional way placing on the MCPCB
the only option I would see would be a hack replacing the front panel PCB
simply have it with holes and let the LEDs shine through them, basically all parts are on te back, but diodes flipped so the emitters shine through the holes
The inner ring of emitters appear to be the 6500K & 3000K, arranged alternately.
The outer ring of emitters appear to be the 5000K & 4000K, arranged in pairs alternately.
The sample here appears to be arranged slightly differently:
inner ring is similar: 6500K & 3000K alternate
outer ring is now alternate 5000K & 4000K (not in pairs)
I will also try to make a front cover PCB with aux LEDs integrated shining through the board
I sent this pm to Hank:
I found that you can do D18 custom builds.
Can you: 1. do one with Nichia 219b’s? or: build one up that would be the equivalent tint/cri of the 219b 4000k? (the slightly rosy tint)
I already have one with the sst-20’s and I absolutely love it but it is kinda yellow.
We’ll see. Someone had a d18 on bst with 219B’s that I missed and I’m sick at heart…
You can always buy the d-18, and send it to a modder in the states, I know of one that has 219b’s and has done work for me before.
I had Hank put (6x)sst-20 6500k and (12x)sst-20 3000k and I love it!
Would E21As work in the D18?
Nope.
The D18 MCPCB and driver are all wrong for E21A, and I’m not sure if the optics are compatible.
So… at minimum, it would require building a new driver and new MCPCB and greatly reducing the maximum power level.
The D18 uses the LEDil LISA optics. The manufacturer lists here that the LISA II is compatible with the E17A, and it has a 82% percent optical efficiency. The LISA III is shown here as being compatible with the Optisolis and the somewhat large 219F.
I have a custom Emisar D18 with deep red 660nm SST-20-DR-B120-V660 emitters. It is very bright on turbo.
One of my D18s was made with W1 Reds. It is ridiculous on turbo. When you start low and ramp up it goes from, yep that is really red, starting to get brighter, to so bright the white ceiling reflection hurts your eyes when you look away. I have no real use for the light, but it is still one of the coolest lights I own. It would be interesting to contrast the w1 and the sst20 version.
If you’re mixing tints… The farther apart the two tints, the less green and more pink the result will be.
So… 4000K + 5000K is only slightly less green than 4500K. But 2700K + 6500K is significantly less green. This is because the color space is curved, but the tint mix follows a straight line. For example, here’s how it looks with 3000K + 5000K:
