that would be an option, jupp
By the way: Is there a âshipping proges page?â I am #30xx and would like to know, when I could âroughlyâ expect shippingâŚ
But not impossible.
HDS is using a wire with a rotating head and a fixed MCPCB for the button, Novatac is using a spring with a rotating head and rotating button.
The end of the tube on the driver side of the HDS is anodized, the trace on the MCPCB is for the end of the wire.
The spring of the novatac is working the same as the inner tube of the FW3A, but with time if the spring wears off, it wonât be a problem due to its adaptable length.
I think that is the thinnest retaining ring I have ever seen. When I first went to check mine for tightness I didnât even see it & thought⌠âoh crap, itâs glued after allâ. :person_facepalming:
But after closer inspection, there it was. Both of mine were tight btw. :+1:
