FW3A Troubleshooting / FAQ
1388 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 3 hours 21 min ago
Standard procedure for any new flashlight is to make sure all threaded parts are tight. Things tend to loosen during shipping Wink
Lexel
Lexel's picture
Last seen: 2 days 19 hours ago
its not the shipping its the boss telling their worker: “assemble faster or you get fired”
teacher
teacher's picture
Last seen: 11 months 1 week ago
Most likely…. Wink
steel_1024
steel_1024's picture
Last seen: 1 week 39 min ago
Firelight2 wrote:
Discovered an issue today:
I also encountered the same problem.
Sorry for my poor english.
steel_1024
Several times now after inserting the battery at the head and then screwing closed the light I’ve noted that the head sometimes stops screwing down a couple mm before it should. This appears to be caused by the inner switch contact tube being slightly off-center and hitting the edges of the narrow driver retaining ring. When this happens the inner tube does not make contact with the driver and the light does not work.
If this occurs, the light can still be screwed down by unscrewing and then rescrewing the head in several times until things line up right. But that doesn’t solve the problem and is frustrating to do. This issue occurred with both my FW3As.
Analysis and Solution:
The problem appears to be caused by the driver retaining ring not being screwed tight to the driver at the factory. If you encounter this issue, use tweezers to turn the driver retaining ring so that it is flush against the driver. Once the retaining ring is snug, this problem goes away completely.
In addition to tightening the retaining ring.
Also align the 2 notches shown in the figure below.
teacher
teacher's picture
Thank steel for the additional advice & photos. That step is invaluable to know also…… Beer
You and Firelight2 have save people a ton of annoyances by your postings! Thumbs Up
If they will only read them that is…. Facepalm . Big Smile . Big Smile
ToyKeeper
ToyKeeper's picture
Last seen: 6 min 5 sec ago
steel_1024 wrote:
In addition to tightening the retaining ring. Also align the 2 notches shown in the figure below.
Thanks for posting about this and including pictures!
That confirms the driver isn’t glued, and it also confirms the driver fit issue is completely fixed.
Also, if someone doesn’t know there’s a notch in the driver, it can be easy to miss… and then it’ll be confusing to figure out why the light doesn’t fit together quite right.
PBWilson
Last seen: 4 hours 8 min ago
teacher wrote:
Most likely…. Wink
How the heck is she supposed to catch up on new YouTube videos, sip her coffee and discuss the latest Game of Thrones episode? Wow!
A big thanks for troubleshooting the retaining ring and pointing out that notch. I’ll check mine when it arrives.
steel_1024
One of my 2 FW3A is not tightened.
This ring is very thin and the structure may not be very strong.
Maybe bring the retaining ring out when disassembling the battery.
But the chances should be small. Because it is not easy to disassemble.
Some retaining rings may have Burr.
You can take it off and trim it, or grind it with sandpaper. (Observant)
Ryzbor
Ryzbor's picture
Last seen: 11 hours 55 min ago
Alright, so what do I have to do to run three red XP-E2’s (max 2.5-3.0A/led) safely in the FWA3?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
M3CSL
M3CSL's picture
Last seen: 10 months 6 days ago
I was hoping somebody would run 3xXHP50.2 3V in there Big Smile But I haven’t seen any triple MCPCBs that would fit.
The end result would probably be a hot light after 2 seconds.
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
KawiBoy1428
KawiBoy1428's picture
Last seen: 10 hours 37 min ago
Disable or take the FET off…run off the 7135’s…..
KB1428 “Live Life WOT
Ryzbor
Ryzbor's picture
Will the UI work with a removed fet?
KawiBoy1428
I don’t know on this FW3A, but I have blown FET’s on FET+1 7135 drivers and the lower modes still worked……..
Take one for science… Big Smile
Firelight2
Firelight2's picture
Last seen: 2 hours 19 min ago
That would work, but keep in mind that without the FET the driver will only supply 2.8 amps. That’s less than 1 amp per LED which is well below the rated max that you described of 2.5-3.0 amp.
If you want something closer to the max possible output of a red XPE your best bet is to modify the firmware or download firmware someone has modified. Wasn’t TK working on a lower amp firmware for LEDs like this and Oslon white flat?
iamlucky13
Last seen: 3 hours 33 min ago
There is a firmware sub-version in her repository for anyone who wants to be conservative with the 219B. It limits the FET channel to 50%. It is also possible to create your own firmware version with different ramp levels.
Because the red XP-E2 has a low forward voltage (and the photo red and far red even lower still), it is probably advisable to avoid FET use entirely unless you’re willing to risk killing a set.
On the other hand, the red and green XP-E2’s seem to have fairly high foward voltages and might work ok with FETs.
Source – XP-E2 datasheet, plus DJozz tests:
http://budgetlightforum.com/node/32452
xevious
xevious's picture
Last seen: 1 min 35 sec ago
Thank you for providing this information. Hopefully it’s an uncommon situation, as it’ll be frustrating to have to purchase a pair of split ring pliers sufficient for the job.
ToyKeeper
ToyKeeper's picture
If the ring is loose, tightening it is pretty easy. A toothpick or a nail can generally do the job. But if the ring is tight, loosening it may require better equipment.
KawiBoy1428
Remove the FET then add more 7135’s for your desired current.
Firelight2
Is there room to add more 7135s? I’m not sure there’s enough room to stack them.
KawiBoy1428
There is room to stack them, might have to add a taller spring….maybe, or use a button top?
. I just sat a 7135 on top at 3 O’clock
. Where there is a will there is a way….
Firelight2
I wasn’t so concerned about the spring. I was thinking that with another row of 7135s would there be enough room with an 18650 installed for the battery tube to still close fully. This is one light that has to be screwed tightly together or the switch tube won’t make contact at both ends.
KawiBoy1428
Well I’m not concerned in the least…. just throwing suggestions out there, you don’t know unless you try, thats what modding is all about, if it don’t work, fall back, regroup and attack, repeat… Personally I like the light just as it is, well these 2×3D FW3A’s I got, no modding needed, but the next 2 warm yuck yellow FW3A’s will be subjected to all kinds of ……fun!
. If you run out of room, maybe a contact on the cap end?
saypat
saypat's picture
Last seen: 1 hour 19 min ago
If the ring is loose, tightening it is pretty easy. A toothpick or a nail can generally do the job. But if the ring is tight, loosening it may require better equipment.[/quote]
can we assume that tightening would be ‘clockwise’? Thanks.
Firelight2
Yes.
The retaining ring uses the same threads that the battery tube uses to screw into the head. So yes… turn clockwise to tighten.
xevious
xevious's picture
Thanks, TK. I was just concerned about tightening enough so that it doesn’t loosen later on. I have a cheap pair of split ring pliers that is a little soft—the tips can bend—and I’m just waiting to spot a good deal on a new pair.
delusional
delusional's picture
Last seen: 5 months 17 hours ago
What’s a nubbin? It’s not much.
It’s a little cylinder of plastic, shown on the left here:
Picture credit to JasonWW
The nubbin fits into the center ring of the larger piece of rubber, and they both go into the FW3A’s switch mechanism.
The Switch of an FW3A will not work without the nubbin.
______________________________________
When you twist off the tailcap of an FW3A, the switch mechanism falls apart.
They were saying something about glueing the switch, but it didn’t happen, might happen in the future, who knows?
In the meantime, the nubbin is very easy to lose. I opened my tailcap once with no problem, but on the second time I lost my nubbin.
I didn’t even know there was “nubbin to lose.” So I wasn’t really watching for it. Now I need a new nubbin.
_______________________________________
It took me about three minutes to make a new nubbin.
I took out one security bit, marked CR-V4, from a set.
You can see it’s got an outer rim and a cup in the middle. This is designed for “security” screws.
_________________________________________
Next I hammered the bit through a plastic drink bottle cap. See the left hole? This did not work because my nubbin got stuck inside the cup of the bit. I damaged the nubbin prying it out.
On the second attempt I stopped a little short, leaving a bit of plastic remaining around the outer ring, and the nubbin was still attached to the cap. I cut the nubbin from the cap with a knife.
See the nubbin on the right, still attached?
And finally, you can see my new nubbin, in it’s new home, ready to reinstall in my FW3A.
It seems to work really well. …. at least it’s been holding up very well for a few hours.
You also see the drill bit on top, and on the left, the nubbin that got damaged.
I had a half dozen more bad puns ready to go, but decided it’s better if I don’t.
If others would like to join in, there’s nubbin stopping you.
Woke up to this one day…
Good morning OCF&BD,
I’ve created a new disorder for you. OCF&BD
Obsessive Compulsive Flashlight & Battery Disorder – and of course, there is no known cure, because you keep recharging yourself.
JaredM
JaredM's picture
Last seen: 6 hours 38 min ago
I wonder if a large-ish drop of super glue (or similar) on the rubber insulator/seal would work to replace a fugitive nubbin?
pennzy
pennzy's picture
Last seen: 4 hours 47 min ago
Super glue usually does not stick well to rubber. Goop works well with both plastic and rubber.
delusional
Best to just leave the tailcap alone, don’t take it off. Insert the battery from the head.
There’s a warning in the box, stating this.
