It has plastic lens, and while I have nothing against plastic lenses since they will throw further and have clearer die projection than most commercial available glass lenses with LED emitter it does not fit in mine project…
I need glass lens in zoomie(small lightweight and practical zoomie) so that it can hide laser emitter (VCSEL) imperfections or better to say to make them blurry…
This is how VCSEL looks under plastic(acrylic zoomie):
Glass lenses should kinda merge(blur) that imperfections which plastic/acrylic lens perfectly projects…
@luminarium iaculator — have you looked into the Trustfire Z9? Glass lens according to mfr, 1” body diameter, not sure about the anodized threads…. 12 dollars and change at Fasttech.
USB charging in the Ultrafire UF-Z9USB, otherwise the same.
The UF-V3 clearly stood model for the Sofirn, definitely no anodized threads though.
Yes it looks interesting but I have concerns that lenses are acrylic/plastic and I can’t see weather it has anodized threads…
It looks fairly well…
I would like that kind of zoomie(or slightly larger) but with anodized threads, glass lens, 25.4mm body, without any gimmick charging ports if possible…
It is very hard to find such one. I’ve been through whole ali and other sites and I can’t find suitable hosts…
Hmmm… Yes… I just need classic glass lenses in small zoomie light(they usually are low precision ones?)…
But that idea of frozen patter from underside of lens or even better on top of the lens looks like a nice experiment. Small round “blur” or “smudge” on top of lens could do…
Guys. Please try the challenge…It is almost unbelievable how hard is to find this below:
“Zoomie(budget smaller one) but with anodized threads, glass lens, 25.4mm body, 1x18650 bat, without any gimmick charging ports if possible…”
There is a neat way of removing the anodizing, forget the name bit I have the stuff at home, its a common oven cleaner. Works surprising well at removing any anodizing it comes in contact with,right down to bare aluminium
I just wanted small zoomie with real glass lenses and glass lens are usually inferior to plastic lenses and they make blurry die projection in direct comparison to acrylic/plastic lenses wich have ultra clear die projection. I need glass one because I need blurry effect with VCSEL laser die…
So once again challenge for you guys:
“Zoomie(budget smaller one) with anodized threads, glass lens, 25.4mm body, 1×18650 bat, without any gimmick charging ports if possible…”
Been through hundreds of models only Sofirn SF30 is close to that but it has freaking 3xaaa body , and I need 25,4mm one
That is real beauty! I ordered one… Everything here but glass lenses
So why not swapp plastic to glass lens?
I think it is turbo hard to find glass one that will work on place of plastic one… Yes it may fit but focal difference… I would not like any overfocus or defocus(black hole ) issues. So finding that is also Sizifus job
I was able to find all kind of stuff and flashlights but I can’t believe that I can’t find the one I need with mentioned criteria: Zoomie(budget smaller one) but with anodized threads, glass lens, 25.4mm body, 1×18650 bat, without any gimmick charging ports if possible…
I have purchased a couple of lights from this seller JKK70 Manta Ray C8.2 all pretty good in my opinion. But yes it is also listed a 15 watts, 7 amps x 3 volts = 21 watts. Who knows, really only one way to find out.
I am kinda new here and I have been wondering why someone has not attacked the voltage on these low voltage emitters this way. Limiting the output voltage and increasing the amperage.
