A while back, I did a quick estimate of the work involved in making something like that, and decided it’s too big a project to attempt any time soon. Also, it’d probably require getting our admin to make BLF function as an identity provider, which requires server changes and SSL, which invokes other complications. The end result would be something similar to a lightweight clone of Kickstarter.
Got Mine last night. First impressions:
It’s a Little Screamer, alright.
The wide optic is better than I expected.
The clip ring is a few thousandths too wide.
Aww man, that switch just falls apart when the tailcap is off. I can see why they wanted to glue it.
Huh. No retaining ring on the switch. Moddable? I guess you’d have to match the threads, and shorten the battery tube to keep the total length unchanged.
I think for the main production run (not the BLF group buy), they should probably ship these with glued cap by default, but with an option for an unglued cap.
