Got Mine last night. First impressions:
It’s a Little Screamer, alright.
The wide optic is better than I expected.
The clip ring is a few thousandths too wide.
Aww man, that switch just falls apart when the tailcap is off. I can see why they wanted to glue it.
Huh. No retaining ring on the switch. Moddable? I guess you’d have to match the threads, and shorten the battery tube to keep the total length unchanged.
I think for the main production run (not the BLF group buy), they should probably ship these with glued cap by default, but with an option for an unglued cap.
I’m afraid you’re mistaken. Or maybe your light is different from mine. There is a small black pellet that is held in place by the rubber disc. I’ll post a picture of it later today.
The rubber piece has a hard plastic piece glued in place right in the middle. It should behave as one piece, normally… but if the glue gets unstuck, it can come out. If this happens, it’d probably be a good idea to glue it in place again.
Your right Jason, I was indeed mistaken!!
Mine had just stayed together on previous disassemblies. I just now checked & it is indeed 2 seperate pieces… just like you said. :+1:
