Simon replied that he’d send me a new driver if mine was defective. So I went ahead and tried enabling and disabling memory mode a couple times. Turns out it works fine.
If you are in the US I can send ya a OP reflector for the S2+. I have more than a few laying around. Also have some waffle type 60 degree TIR’s as well. Very nice floody beam. PM me with a address if you would like one or two.
Thanks for the offer, but I think I’m going to leave this one as is, as it does have a pretty nice beam. I want to try my hand at building one, so when I do that I’ll order a host that includes an OP reflector. So I’ll have this throwier one and a floodier one.
:edit:
Actually, maybe I would like to have it to play around with. I’ll pm you.
Yes, the issues are pretty random. It depends on the state some individual bits of RAM decay to when power is removed. Basically, the batch the driver is from seems to determine the odds of having a problem, but it is not a certainty. Issues didn’t show up in any pre-production drivers, but only a few were actually tested.
Unfortunately, that wasn’t the only issue. For example, the production drivers were a different design from a different manufacturer, so the firmware was calibrated for the wrong hardware.
just receiving my 2 convoy S2+ ordered in mid April ( one with SST20 & one with Nichia) and unfortunately i got the same problem (all of them). i cannot turn off the memory mode. this is annoying.
i already try to contact simon the seller, and i still wait for his reply.
I bought 3 of these SST20 S2+ with biscotti, just because they were so good VFM; I have only powered one up so far and on a slightly different note to this thread and in the absence of finding the information anywhere else - I went into programming mode to change the mode spacing, which worked without error. Unfortunately I programmed the wrong mode in error, so went back into programming mode and changed the mode again; fortunately I got it right this time as I can no longer get into programming mode to change anything - is this a common failure mode and is there anything that can be done to fix it, or is it a good excuse to try and learn processes for reflashing I if one of my batch has failed this way, are my other 2 likely to go the same way?
I’m not concerned about the apparent failure, as it’s failed stuck in a mode I want and they were dirt cheap anyway and I can use them as triple hosts, I was just curious if it’s recoverable or if I’d need to reflash the MCU/replace driver to restore full functionality.
hello everyone, even though i have boungt the new convoy c8 plus, my old convoy c8 clear suffers from the problem of not be able to change mode. i use the 10 times tap but the only thing that happens is that sometimes it changes the power of the light 100% or something like 30%. Is there somethong i can do to fix this beautiful thrower? i don’t hve acces to programming tools and stuff. Thank you in advance.
Concerning the above Biscotti instructions crib sheet, with mode memory on it reads “enter into next mode”. Seriously? The dreaded next mode memory? Wouldn't it make a lot more sense if it were “enter into current/last used mode”?
I’m trying to decide which flashlight I should buy, so last couple of days I’m reading tons of reviews about two specific flashlights for EDC. One possible pick is Convoy S2+ (with orange peel, for flood). So I’m reading what ppl are saying trying to find out the bad things about flashlights I have in my focus.
So, about this firmware issue… I have a question:
I own a MiniPro TL866A programmer. It came with tons of adapters, so I guess the ‘refleshing’ the ‘new’ firmware (if I pick convoy S2+ and get a bad firmware) would be possible with MiniPro TL866A ?
What kind of package is the IC that holds the firmware? And where to find the latest firmware for ‘refleshing’?
You also mantioned ‘gchart’s Babka’. I guess thats another firmware developer for S2+? Where to find his firmware and is it better they better? (I’m gessing…. at github?)
Another (probably kinda) offtopic question: I want a flashlight with orange peel reflector, but I’ve noticed thats S2+ with orange peel reflector comes with 2 group modes, not like others with ‘smooth reflector’ which comes with 12 group modes. Can I get an S2+ with orange peel and latest (bug free) 12 group modes?
twist3r, Simon the manager from the Convoy store will readily change whatever smooth reflector in your S2+ order to orange peel with ease. He in fact can customize whatever order by ordering first the base flashlight and selecting “other payment methods” (you may need to use the AliExpress application, add to the cart then proceed to see the other payment methods option), then postponing the payment. That way you can message him with whatever custom changes required, and he will later adjust the final price for you to pay. You can also tell him that you're a BLF user, and for it he will make you a discount if you will. :-)
If ordering direct from the official Convoy AliExpress store, you can send a message to Simon (the owner of Convoy), to configure what you need.
So you could ask him to get you a Convoy S2+ with XM-L2 with OP reflector (this is the default anyway), then you could specify Biscotti (12 group modes) with 7135x3 if that’s your preferred configuration.
Unfortunately regarding the “buggy” thing, I’m not very certain what causes that to happen, I have had it happen on some people who asked me to check their flashlights (getting stuck). I have also tried changing the buggy Biscotti driver on a Convoy C8+ to a new (not-yet-buggy) Biscotti driver, as the driver board on Convoy C8+ requires minimal soldering only (I’m very poor at soldering or maybe I don’t have a good soldering iron… — I have not been able to unsolder a 7135x8 driver from a Convoy S2+ head “pill” after several tries, for instance…).
Thanks for your reply Barkuti. Currently I’m gathering so much information that I think its better if I slow down a bit, cause my brain is getting stuck like that biscotti memory mode.
I’m new here, and I’m trying not to bother too many people. Still, I have to ask questions because I’m about to order my first ‘smart’ flashlight. What I would like is a flashligth with flood light and with that kind of light that can ‘flood’ the area in front of me (from my feet up to 3-5m, max 10m away without ugly hotsopt light). If it can ‘throw’ light in the distance, thats a plus. Also I was trying to pick 7135x3 because I wanted the flashlight not to get hot too fast and the battery to last longer, but I wasn’t thinking that 7135x3 would give less lumens compared to 7135x8. Can someone tell me if I’m correct:
If Cree XML2 gives… 1040lm and I pick 7135x8 but use it at 10% mode, that will give…~ 104lm and the flashlight wont get hot too fast and battery will last longer, with light enought to clearly see whats in front of me, without hotspot light (if I pick orange peel)?
