TLF/BLF/Lumintop FW3A review (18650, 3x XP-L HI cool white)
284 posts / 0 new
iamlucky13
Last seen: 2 hours 15 min ago
As a first approximation, expect 15% less at 3000K compared to the cool white
I’m basing this on what Cree specifies in the datasheet for the best flux bin of each color temperature.
Like DB Custom says, the datasheet doesn’t tell you everything, and even what it does varies. The worst bin of 3000K would rate at 25% less than the best bin listed of any XP-L HI color temperature. The best bin of the 3000K against the worst bin of the cool whites would only be 6% lower output.
Since max output of the FW3A depends on a FET, you can also get significant differences if the forward voltage is different.
Narmattaru
Narmattaru's picture
Last seen: 7 hours 53 min ago
awesome review, thanx!
"How to choose flashlight, Main things in simple words":http://budgetlightforum.com/node/68418
aginthelaw
aginthelaw's picture
Last seen: 39 min 34 sec ago
DB Custom wrote:
Here ya go HC, 18 Samsung LH351D W6 5000K with domes sliced off, in moon mode…
Future FW3A buyers can look forward to the day the Samsungs are available, or mod their new lights. Wink
I’ll take it. Do you need my shipping address?
Did shaving make them throwier (is that a word)? How much was the tint shift?
never fear shadows…it means a light shines nearby
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 hours 16 min ago
I’ve shaved all the LH351Ds I have, it made them throwier (more throw than a X-PL HD, less than an HI… maybe more throw if you cut very close to the phosphor?), the color temp goes down ~500-1000 degrees and the tint gets rosier depending on how much you slice off. I took off maybe 1/2 of the height of the dome to get the result I wanted.
Tests of them show about 10-15% output loss at most power levels, and I’d say it looks that way to my eyes as well. In the same host at the same current a shaved 4000K got pretty close to the throw of a stock 4000K SST-20 and had a wider beam.
aginthelaw
I really need to learn soldering. Sounds exactly where i need it to be
BurningPlayd0h
If you’re bold/stupid/have steady hands you could partially shave some lights without removing the MCPCB. Not saying that it’s a good idea or that I would ever do that out of sheer laziness but it’s possible. Wink
stephenk
stephenk's picture
Last seen: 1 month 6 days ago
Are there any videos available showing how to change optics on the FW3A?
M3CSL
M3CSL's picture
Last seen: 4 months 1 week ago
I haven’t found any, but you’d just have to unscrew the bezel, change the optics and screw it back again.
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
maukka
maukka's picture
Last seen: 1 day 21 hours ago
Received my production FW3A w/ XP-L HI 3D today. Works perfectly, even though I did tighten the driver retaining ring before even turning the light on for the first time. The finish is just slightly lighter and bluer than the proto.
The little protrusion on the clip ring is perfectly fine. It helps with the cigar grip, while the proto with a narrower ring is a bit slippery.
The emitters aren’t rosy for sure, but I’ve noticed that lower CRI emitters don’t look as green as for example CRI90 219Cs with similar duvs. This measured 4600K duv 0.0063 at 1×7135, but visually was alright. Gets closer to BBL on higher modes (8×7135, FET). The fine visual experience is also explained by my current ambient lighting conditions that are even greener (4800K duv 0.0085) because of UV blocking windows and lots of trees outside.
Integrated, the tint is not as bad as in the hotspot. So there is some tint shift in the beam but it’s not very visible to the eye. Output is 139 lumens in the 1×7135 mode.
Nichia 219b sw40 integrated at 1×7135, 83 lumens:
JasonWW
JasonWW's picture
Last seen: 29 min 45 sec ago
Your 3D doesn’t look rosy? Mine sure does. I like it.
Click this to go to signature links.
Tom E
Tom E's picture
Last seen: 17 hours 36 min ago
I'm not sure what the graphics all mean, never did understand, but where can I find the results regarding above/below the BBL? What's the test result relative to the BBL?
I find my 3D FW3A surprisingly more blue/green than rosy.
maukka
maukka's picture
Duv (delta uv) is the metric which shows how far and in which direction the source is in reference to the BBL. Positive duv is green (yellow on low CCT sources), negative is rosy/pink/magenta. At least to me, some emitters seem visually more neutral on a white wall than others even with similar CCT and duv. Even a slight tint shift within the beam also affects how the beam on average is perceived even if it’s not obvious on non-rainbow like emitters like the XP-G3.
I would consider duv ±0.0030 neutral. The 219C CRI80 or XP-L HI in CRI70 look neutral even above 0.0030, but most CRI90 emitters do look greener even when they are closer to the BBL. SST-20 for me is the worst in this regard, looking greenish even when it’s near the BBL.
Objectively, the 3D in my FW3A is greenish, but much less so when evaluated visually. Most high CRI emitters we use would look pretty horrible at duv 0.0060.
maukka
maukka's picture
The 3D had to give way for some dogfarts (LH351D 5000K CRI90) and a slight minus green filter (Zircon 804) and Carclo 10507.
1×7135 output dropped from 139 lm with XP-L HI to 125 lm with just the emitter change. 10507 brought it up to 126 lm and finishing with the minus green got me 112 lumens.
FET output at turn on (30Q):
XP-L HI 3D: 3035 lm
LH351D dogfarts: 2626 lm
with 804: 2334 lm
Final results is under BBL with 1×7135 and full FET.
candor
Last seen: 1 week 2 days ago
maukka, any chance you have some comparison beamshots?
maukka
maukka's picture
Nothing on the LH351D version, but here’s 219B sw40 vs. XP-L HI 3D on a white wall and a floor with reddish tint. Should be obvious which is which.
candor
I appreciate it. I’m curious about the dogfarts with the 10507. Are you pleased with it? Beam profile-wise?
komeko
komeko's picture
Last seen: 4 hours 48 min ago
Maukka, did you have an XP-L HI 7A emitter in your hands? I am interested in measurements and how it falls in FW3A.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
maukka
maukka's picture
No, I don’t have the 7A.
hodor
hodor's picture
Last seen: 3 hours 47 min ago
maukka wrote:
LH351D dogfarts: 2626 lm with 804: 2334 lm
Stock or de-domed/sliced?
maukka
maukka's picture
Dome on.
It’s pretty much a wash between dedoming and filtering when it comes to output. If you want a tighter spot, then dedome away, but for me, I kinda like the wide even spot of the stock LH351D and 10507. Great for closeup work while still retaining some throw.
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 6 min ago
maukka wrote:
some emitters seem visually more neutral on a white wall than others even with similar CCT and duv… The 219C CRI80 or XP-L HI in CRI70 look neutral even above 0.0030, but most CRI90 emitters do look greener even when they are closer to the BBL. SST-20 for me is the worst in this regard, looking greenish even when it’s near the BBL.
That matches my experience too. Perhaps I should finally get a sheet of minus-green material and stop being so picky about which emitters are used. Almost everything is going to look green, so I should put some rose-tinted glass over it to make things look better.
Firelight2
Firelight2's picture
Last seen: 40 min 1 sec ago
Lee Minus Green filters are great stuff!
I have a #279 filter in my modded FW3A right now. It’s not a Zircon filter so probably won’t last super-long in high-brightness LED applications. But on the other hand it came in a roll big enough for a hundred small flashlights.
It does reduce output 14% and makes the tint warmer though. Currently using it with 2× 5D and 1× 3D emitter.
Flashaholics
Flashaholics's picture
Last seen: 3 hours 16 min ago
Banggood.com have just sent me 2 XPL HI 5000K for review, I’m not sure why they sent me 2 but they are very very different
One has a frosted optic and Nichia Like tint the other has a clear optic and yellowish typical XPL 5000k tint.
The frosted one gets anywhere from 2800 to 3700 at turn on and the clear optic one gets 2600 every time.
The Frosted one is also temperamental in muggle mode, often doubling it’s power to 600ish lumens.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - https://www.youtube.com/c/FLASHAHOLICS_GB
d_t_a
Last seen: 1 hour 36 min ago
How do the optics look like?
Below is a sample of the “plastic optic”, Carclo 10511, and Carclo 10507 optic on the FW3A.
Flashaholics
The frosted one looks like the middle light but my clear optic is different from the clear one in the pic, mine doesn’t have the 3 spokes in the middle.
DB Custom
DB Custom's picture
Last seen: 1 hour 17 min ago
It’s likely your clear one has the copied optics made in China. It’s supposed to have lower lumens and yours exhibits that behavior. Replace it with a factory Carclo 10507 and you should see a pretty nice lumens increase.
Flashaholics
Cheers. Lumintop contacted me asking why banggood was all over the review, I forgot they’d also sent me one, oops.
cabfrank
Last seen: 9 hours 33 min ago
I had no idea there were clone 10507s out there. Thanks Dale, i will check mine.
DB Custom
DB Custom's picture
I was not in the group buy but have recently been looking at the Titanium variant. I noticed an alert on Neal’s pages about lower numbers out of a cloned, made in China, optic. I still haven’t bought one but was looking at the sapphire lens to go with the Ti/Cu FW3A and as I already have clear spot optics that part wasn’t a concern for me… a little surprising but not really a big deal as they are so easily changed out.
The polished copper has an appeal to me as well … always something, isn’t it?
monkeyman77
Last seen: 1 month 1 week ago
anyone got a link to the runtimes in steped mode?
