Interested
[♛ FreemeGB] FireFlies E01 LUMINUS SST40W N5 5700K 2300lm Andúril 27100/18650 EDC Flashlight - ENDED
Interested.
Interested
Interested.
No chance, this type of driver would kill it.
Interested.
It’s a single LED light. See from the picture I posted just above your comment. My comment was it would take a triple to get that many real lumens.
interested.
Interested.
Interested
What is the lumen, on title it’s 3500 but in post it’s 2300 lumen
But whatever, i’m in
How about steel bezels like in the E07?
My bad, forgot to change it as i was using MM6S template. Light is rated it as 2300lm by Fireflies. TS is right, actual output should max out at 1800lm based on his SST40 emitter test.
3500 lumens as a triple. I’ve got the Luminus SST40W N5 spec sheet up now. 1806 lumens at 6 amps, 1603 at 5 amps, 1115 at 3 amps. It’s a nice light with a good price but output needs to be a bit more honest. The TRI lens is a great feature.
Interested
interested
Interested
I just got info from Jacky that the MCPCB is 20mm x 1.6mm but there is room to fit MCPCB with diameter less than 21.5mm. Therefore the Virence VR21SP4 should fit nicely for anyone interested in modding this with the quad E21A.
texas shooter:3500 lumens as a triple. I’ve got the Luminus SST40W N5 spec sheet up now. 1806 lumens at 6 amps, 1603 at 5 amps, 1115 at 3 amps. It’s a nice light with a good price but output needs to be a bit more honest. The TRI lens is a great feature.
Then I’ll say at 1800 lumens, TRI lens, 21700 battery under $30.00 I’m interested.
Interested.
Interested.
Robert
