Nitecore LA10 XP-G2 S3 4Modes Magnetic Tail Maintenance Light Flexible Camping EDC LED Flashlight Work Light
(Preorder) Exp:2019-03-31
Normal price: $24.95
Coupon Price: $16.99 (the lowest price)
Price breakdown:
Processing time: Expected on March 17, 2019
Specification:
Brand | LUMINTOP |
Type | natural white cool white |
Flux | 1000 lm |
Throw | 400 m & ~50Kcd |
Battery | 14500 battery (can't work with AA battery) (not include) |
Driver | Texas avenger FET driver |
Reflector | 29 mm ID, aluminum, smooth finish |
Lens | Glass with anti-reflective coating |
Body | Aluminum with Type III hard-coat anodizing |
Button | Tactile with back-lit rubber boot |
Waterproof | Equivalent to IP65, do not immerse in liquids |
Dimensions | 36 x 105mm / 1.42 x 4.13inch |
Weight | 70g |
Features:
[1] By default the GT micro is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Package include:
1 x Flashlight
Note: not include battery
Thank you in advance for clicking on this link!
This light has a magnetic control ring and uses either a 16340 or 18350 battery. You can dim it down to the point that you have to be in complete darkness in order to see the light 8-) It is quickly becoming my favorite EDC!
The 16340 battery that comes with it has a built-in micro USB charger. It also comes with a Allan wrench, two extra clip screws and an extra o-ring.
Specifications:
Brand | JETBEAM |
Material | Aluminum |
Mode | Highlight - low light - SOS - strobe |
Brightness | 950 lumens |
Waterproof | IPX8 |
Features:
The body of this flashlight is built of high quality aluminum alloy, and it has a very solid construction
-Internal wiring applies the high efficient booster circuit, and can utilize the batteries in the largest extent.
-Excellent waterproof, suitable for outdoor environment, adverse weather conditions except for diving
-Focus function that allow the beam can be focused.
Package included:
1 x Flashlight
1 x Hand strap
1 x Clip
1 x Battery
2 x Waterproof ring
Order Subtotal: US$38.40
Coupon Discount: US$6.41
Grand Total:US$31.99
Use Coupon code: BGLZ1
Order Subtotal: US$32.02
Coupon Code: BGCM2
Coupon Discount: US$5.03
Grand Total:US$26.99
Specification:
Emitter Type: | XPL HI with copper DTP plate |
Color Temperature: |
6500K white tint
5000K neutral white tint
4000K neutral white tint
3000K warm white tint
Driver: | 7135*8 with biscotti firmware |
Battery Configurations: | 1x 18650 lithium battery(Not included) |
Lens: | Glass |
Material: | Aluminum alloy |
Reverse Protection: | Yes |
Low Voltage Warning: | Yes |
Mode Memory: | Yes |
Tailstand: | Yes |
Color: | Black |
Weight: | 110g |
Size: | (Head x Body x Tail x Lengh):31.6mm x 25.8mm x 27.5mm x 135.2mm |
Convoy S2+ Nichia 219C 4000K 5700K 7135*4 1400mAh Driver 12 Groups Mode 18650 LED Flashlight - 4000k
Order Subtotal: US$20.64
Coupon code: BGC219C
Coupon Discount: US$3.65
Grand Total:US$16.99
Specification:
Emitter Type: | SST20 high CRI 95 with DTP copper plate |
5700K Cool White
4000K Neutral White
Driver: |
7135*4 biscotti firmware: output current 1400mA
Lens: | Ar-coated Glass |
Tailstand: | Yes |
Color: | Black |
Weight: | 76g |
Size: | (Height x Width):118mm x 24.1mm |
Product name: | BLF X5 XPL HI LED Flashlight |
Brand: | BLF |
Model: | X5 |
Emitter Type: | XPL-HI |
Circuit Driver: | ATTiny25V-based driver with off-time capacitor and FET+7135 power channel configuration. |
Light Tint: | 1A (6500K),3B(5300K) |
Material: | Constructed from aero grade aluminum alloy |
Mode: |
1 -- 1400 lm 2 -- 5, 1400 3 -- 5, 293, 1400 4 -- 5, 135, 543, 1400 5 -- 5, 79, 293, 688, 1400 6 -- 5, 54, 178, 419, 813, 1400 7 -- 5, 47, 135, 293, 543, 858, 1400 8 -- 5, 35, 99, 213, 365, 613, 953, 1400 |
Battery Configurations: | 1 x 14500 battery (not included) |
Working voltage: | 2.8-4.35v |
Switch Type: | clicky |
Switch Location: | tail of the flashlight(Lighted tailcap by pilotdog68) |
Impact Resistant | 1 meter |
Lens: | Toughened ultra-clear mineral glass with anti-reflective coating |
Reflector: | Smooth reflector |
Carrying Strap: | included |
Waterproof: | IPX-8 waterproof 2 meters |
Color: | silver |
Weight: | 236g without battery |
Size: | 105mm x 28mm(length x body diameter) |
Order Subtotal: US$301.02
Coupon Code: 6ab60b
Coupon Discount: US$101.02
Grand Total:US$200
Specification:
Product name: | NITECORE TM10K Tiny Monster 10000 Lumen LCD Display Burst Rechargeable Flashlight |
Brand: | NITECORE |
Model: | TM10K |
Emitter Type: | 6x XHP35 HD |
Max Output: | 10000 lumens |
Range: | 315 yards |
Mode: | Turbo, High, Mid, Low, Ultralow |
Lumens: | Turbo: 10,000 lumens High: 400-2000 lumens Mid: 300 lumens Low: 100 lumens Ultralow: 3 lumens |
Runtime: | High: 2 hr Mid: 7 hr Low: 14 hr Ultralow: 200 hr |
Battery Configurations: | 4800mAh li-ion battery (Built-in) |
Switch Type: | Clicky |
Switch Location: | Body side of the flashlight |
Impact Resistant | 1 meters |
Waterproof: | IP68 - 2m submersible |
Color: | Black |
Weight: | 8.7oz |
Size: | 4.33" x 1.61" x 1.22" (L x W x H) |
Features:
Package included:
4.98 out of 5 See all 55 reviews
Order Subtotal: US$35.89
Coupon Code: candleled
Coupon Discount: US$0.90
Grand Total:US$34.99
Description:
What is Candela?
Candela is the world's only smart candlelight using the latest Bluetooth (BLE) Mesh technology, combining the warm comfort of candlelight with the convenience and control of smart technology. The BLE Mesh technology allows up to 30,000 units candelas to communicate with each other.
Specifications:
Brand: Yeelight (Xiaomi ecological chain)
Voltage:5V
Power: 6.5W
Power Supply: USB
Lumens:0.3-13lm
Light Color: Warm White(1800k)
Control Range: 20m
Battery Type: 2100mAh
Size; 72*195mm
Features:
Brown copper candlelight simulation
Minimalist design, rotation control, IoT smart device
Simply rotate a Candela to control all connected candelas
Control your Candela and other Yeelight smart lights with Android or iOS apps.
The built-in 2100mAh battery allows for up to 8 hours of continuous use on a single charge.
Candela fits perfectly in any bar or restaurant or any scenes.
Package Included:
1 x Yeelight YLFW01YL Night Lamp
4.99 out of 5
407 Reviews
Specification:
Product name: | BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight |
Brand: | BLF |
Model: | Q8 |
Emitter Type: | XP-L HD V6 3D |
Light temperature: | 4750K-5000K |
Light color: | Neutral White |
Mode: | Smooth ramping or mode set operation |
Material: | Aerospace grade aluminum alloy construction |
Total Emitters: | 4x |
Battery Configurations: | 4 x 18650 or unprotected button top (not included) |
Working Voltage: | 3-4.2v |
Switch Type: | Electronic switch |
Peak Beam Intensity: | 50,000+ cd |
Impact Resistant | 1.2meters |
Max Output: | 5000+ lumens |
Range: | 450+ meters (max) |
Lens: | High transmittance glass |
Reflector: | Aluminum alloy mirror reflective cup |
Waterproof: | IPX-8 waterproof |
Color: | Black |
Weight: | 400g without battery |
Size: | 132mm x 59mm x 50mm(length x head x body diameter) |
Features:
• Compact and lightweight 5000 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Mode,Lumens and runtime:
Mode Groups: | Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data ) | |||||||
Group1: | Moon 2LM/1500h | Turbo 5000LM/40min |
Group2: | Moon 2LM/1500h | Low 160LM/33h | Turbo 5000LM/40min |
Group3: | Moon 2LM/1500h | Low 70LM/66h | Mid 1250LM/8h | Turbo 5000LM/40min |
Group4: | Moon 2LM/1500h | Ultralow 10LM/150h | Low 160LM/33h | Mid 1500LM/6h | Turbo 5000LM40min |
Group5: | Moon 2LM/1500h | Ultralow 10LM/150h | Low1 70LM/66h | Low2 160LM/33h | Mid 1500LM/6h | Turbo 5000LM/40min |
Group6: | Moon 2LM/1500h | Ultralow 5LM/150h | Low 70LM/33h | Mid1 240LM/17h | Mid2 1100LM/10h | High 2500LM/3h | Turbo 5000LM/40min |
Group7: | Moon 2LM/1500h | Ultralow1 10LM/400h | Ultralow2 35LM/140h | Ultralow3 95LM/54h | Low1 160LM/33h | Mid 1350LM/8h | High 2500LM/3h | Turbo 5000LM40min |
Group8: | Moon 2LM/1500h | Low 160LM/33h | Mid 750LM/17h | High 2100LM/5h |
Group9: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 520LM/20h | Turbo 5000LM/40min |
Group10: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 1500LM/6h | Turbo 5000LM/40min |
Group11: | Moon 2LM/1500h | Low 160LM/33h | Mid 1350LM/8h | Turbo 5000LM/40min |
Group12: | Moon 2LM/1500h | Ultralow 5LM/600h | Low 150LM/33h | Mid 1700LM/5.5h | Turbo 5000LM/40min |
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
How to use the UI: bit.ly/narsilinfo
For the safety to the battery: bit.ly/lionsafety
For more information to see: bit.ly/blfq8
Product review from BLF Forum:https://budgetlightforum.com/t/-/39069
Sofirn SP70 is a powerful outdoor flashlight designed for outdoor activities like camping, hiking, fishing or hunting. It can be operated with two 26650 or 18650 (with sleeves) Lithium-ion rechargeable batteries. Tail switch powers on / off, side switch controls two mode groups: Group 1 with 6 brightness levels and Group 2 with ramping capability.
https://www.banggood.com/Sofirn-SP70-XHP70_2-With-ATR-2-Groups-7Modes-5500LM-Ultra-bright-Tactical-18650-26650-LED-Flashlight-p-1446325.html?p=R4240016492493201711&custlinkid=219321
Specification:
XHP70.2 LED with a lifespan of 50,000 hours
Working Voltage: 5.6 V - 8.4 V
Battery Options: Two 26650 or 18650 Li-ion batteries
Dimension: 250mm (length)× 90mm (head diameter)
Weight: 625 grams (without batteries)
Flashlight body: 6061 aluminum alloy, CNC manufactured to Military Grade Specification type III hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry.
Toughened mineral glass lens
The waterproof level: in accordance with IP68
Reverse polarity protection from improper battery installation
Mode Memory:Last mode remembered - it memorizes the last brightness level used in the general modes (except Beacon)
Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 60°C (140 °F) to prevent overheating
Automatic Stepdown: Turbo mode steps down to High mode after 3 minutes of operation to prevent overheating. High mode steps down after 30 minutes of illuminating.
Power Indicator: Turn on the light, the side indicator shows the battery power for 5 seconds. Green is good enough power, orange is half power, red is short of power, flashing red is power running out, please replace or recharge batteries ASAP. In Standby Status, the indicator is Green as locator in the dark.
Operation Instruction:
Half press the tail switch for momentary-on. Fully press tail switch to power on or cut off. When the light is on, the side switch controls all flashlight functions as follows:
Group 1: 6 modes (default group)
Click and hold the side switch to cycle through brightness levels: Eco-Low-Mid-High, release when you find the level you need.
Double-click to activate Turbo mode, one click to return last brightness.
Click to Standby, the main LED turns off but side indicator is green as locator in the dark. Click to turn on the main LED again
In Standby Status
Click and hold to Moon, click goes back to Standby
Four fast clicks to active the lock-out, the main LED blinks twice, the indicator LED turns off. When in lock-out status, only four fast clicks will reactive the light, all other operations only get two blinks
Six fast clicks change from Group 1 to Group 2 or the other way around
Eight fast clicks to active Beacon which light up 0.1s in every 2 seconds
Group 2: Ramping
Click and hold side switch to ramp up or down. Ramping changes direction when the button is being clicked and held again within 1.5 seconds; same direction when ramping again after 1.5 seconds.
The light blinks once time when it reaches Moon or Turbo mode.
Click to go to Standby, another click turns on the light.
Package included:
1 x flashlight
1 x strap
1 x replace rubber cap for side switch
2 x replace Orings
2 x key rings
2 xbattery adapter
Product name: | NITECORE MH40GTR LED Flashlight |
Brand: | NITECORE |
Model: | TUP |
Emitter Type: | XP-L HD V6 LED |
Beam Color: | White light |
Peak Beam Intensity: | 8130 cd |
Max Output: | 1000 Lumens |
Range: | 180m / 197yards |
5 Levels Brightness: | Turbo - High - Mid - Low - Ultralow |
Lumens: |
1000lm - 200lm - 65lm - 15lm - 1lm
Runtime: |
15min - 3h - 9h45min - 19h - 70h
Battery Configurations: | Built-in 1200mAh Rechargeable Li-ion |
Battery Voltage: | 3.7V |
Switch Location: | Side of the flashlight |
Material: | Aerospace grade aluminium alloy |
Reflector: | SMO |
Impact Resistant: | 1 Meters |
Waterproof: | IP54 waterproof |
Carrying Strap: | Lanyard |
Color: | Black, Grey |
Weight: | 53.2 g / 1.87 oz |
Size: | 70.3 x 29.5mm / 2.76 x 1.16in (Length x Head Diameter) |
This package doesn't include a 14500 battery and a lanyard.
Added info on moonlight mode.
Lumintop EDC05c Deal $29.99 (<-- click me affiliate link)
Code: EDC05C
Before the Lumintop EDC05c, there was the Lumintop EDC05. The Lumintop EDC05 is a slightly smaller and brighter flashlight, but has the same head design. Where the EDC05c stands out is the addition of a side light that features Nichia NCSLE17 Neutral White LEDs.
1 x Lumintop EDC05c
1 x Warranty Card
1 x User manual
1 x Thank-you card
1 x micro USB cable
The package did not include spare o-rings for the tail cap, it did not include a 14500 battery and it did not include a lanyard. Had it include a lanyard, one would thread it through the hole in the clip.
The main head is equipped with Cree XHP 35 Hi in Cool White with a maximum stated output of 500 lumens and a beam distance of 120m. I have seen a report that measured the output slightly above 400 lumens. I used this light in Luray Caverns and it’s plenty bright. The tour guide’s flashlight (a zoomie) ran low on battery, so I lent him mine. He was surprised at how bright it is for such a small light.
Surrounding the LED is an orange-peel reflector with good depth. The orange peel texture helps soften the beam and the depth slightly increases the throw (beam distance). The depth of the reflector is mainly used for increasing the brightness of the spill.
In terms of built-in protection, when the battery voltage is lower than 3.0V while the flashlight is in use, the flashlight will downshift to low mode. When it is below 2.8V, the light will blink 20 times and then the flashlight shuts off to protect the battery from over-discharge.
The side light is covered by a soft silicone, glow-in-the-dark diffuser that is glued onto the both of the EDC05c. Under the diffuser are 4 Nichia NCSLE17 Neutral White LEDs.
The knurling provides excellent grip, but at the same time, it’s slightly uncomfortable to squeeze because of the somewhat sharp edges of the knurling. The knurling near the head is purely for aesthetics; the rubber seal that covers the micro USB charging port provides the grip for your index finger.
The tail cap is not the usually ones that screws on from the outside of the body (body has the external threads while the tail cap has the internal threads). Instead, it screws into the tail using the included metal tab. This means that replacing the battery won’t be easy if you don’t have the tab or the right tool.
The magnetic tail cap has a brass spring that holds down a very strong magnet (neodynium?). Using either the magnet or a lanyard makes the EDC05c highly usable as a lantern. The side light easily lasts more than a day in low mode, but on highly, my Efest 14500 700mAh V2 does not last long at all.
From Off mode:
From any mode (main light or side light), hold button down for 1 second to turn off. Double press to activate the side light and double press again to return to main light. From any main light mode, press and hold button for more than 3 seconds to activate hidden mode (strobe, SOS and beacon) and double press to entire side light hidden modes (strobe, SOS and beacon).
The EDC05c has a built-in micro USB port with a rubber cover. When charging, the power button lights up red and once it is fully charged, the charging automatically stops (Red LED in button turns off).
Some use cases
The Lumintop EDC05c appeals to both Cool White and Neutral White fans. It has everything that I want in an EDC light and more: portable, rechargeable, neutral white light decent throw. I recommend this light for anyone looking for an all-in-one flashlight that is easy on the eyes.
Pros:
Cons:
The light is regulated, which could be a pro or con.
Stainless Steel Bezel for Astrolux FT03
Brand: | NITECORE |
Model: | TM10K |
Color: | Black |
Weight: | 8.7oz |
NITECORE TIP 2 (TIP2) 720 Lumen USB Rechargeable EDC Flashlight Waterproof Magnatic Mini Keychain Light
https://www.banggood.com/NITECORE-TIP-2-TIP2-720-Lumen-USB-Rechargeable-Flashlight-Mini-Torch-EDC-Flashlight-Mini-Keychan-Light-Magnetic-Attraction-4-Modes-Camping-Hiking-Work-Lamp-Portable-Waterproof-Emergency-Light-p-1470638.html?p=R4240016492493201711&custlinkid=317948
Specification:
Brand | NITECORE |
Maximum output | 720 lumens |
Maximum range | 93 meters |
Maximum light intensity | 2160 cd |
Life time | 55h / 2.29 d |
LED | XP-G3 S3 LED |
Light cup type | Smooth Cup |
Battery | Rechargeable lithium battery |
Body length | 62.6 mm / 2.46 in |
Head diameter | 26.9 mm / 1.05 in |
Product weight | 38.3 g / 1.35 oz |
Features:
Use Coupon code 7Lights
Use Free shipping if you want to save a $1.82
Product Description:
Package included:
1 x Flashlight
1 x O rings
1 x Lanyard
1 x SS Connecting buckle
1 x Flashlight holster
1 x Gift box
US$68.89 US Warehouse
US$90.79 CN Warehouse
Retail Price: US$129.99
The neat thing about this light is that if you wear the Mi Band, such as the Mi Band 4 (soon to be released), the light will automatically dim/shut off once you fall asleep.
Mi Band 4 Price after Coupon: $34.89 https://www.banggood.com/Original-Xiaomi-Mi-band-4-AMOLED-Color-Screen-Wristband-bluetooth-5_0-135-mAh-Battery-Fitness-Tracker-Smart-Watch-p-1498032.html?p=R4240016492493201711&custlinkid=366842
Coupon Code: BGMiband438
Mi Band 3 Price after Coupon: $18.69 https://www.banggood.com/International-Version-Xiaomi-Mi-band-3-Smart-Bracelet-Long-Standby-Heart-Rate-Monitor-Smart-Watch-p-1333022.html?p=R4240016492493201711&custlinkid=366844
Coupon Code: BGMiband318
Description:
Yeelight LED Ceiling Light - The World's First Lamp to Support both WiFi and bluetooth
The Yeelight smart ceiling light is deigned as sporting white color in a circular shape. A moonlight mode which gives the look of the moon when turned on is surprisingly comfortable. Being a smart lamp, the light can be controlled by smartphone through WiFi or bluetooth. It also comes with a bluetooth remote controller that allows you to remotely switch on and off your light without necessarily being in the same room.
Specifications:
Brand:Yeelight (Xiaomi ecological chain)
Input Voltage: 200-240V
Power: 28W
Color: White
Luminous Flux:1800lm ±10% @4000k
Communication Mode: Wi-Fi&BLE
Color Temperature; 2700K-6500K
CRI: ≥95
Brightness: 0.1-1800lm
Platform Supported: Android4.4 and above system; IOS8.0 and above system
Dimensions: 320x320x73mm
Features:
● 5min Fast Installation: innovative coupler module for quick assemble and disassemble
● 95Ra: 240pcs OSRAM LEDs of high CRI provides museum lighting effect
● Cozy Moonlight: the moonlight mode offers warm and cozy lighting
● IP60 Dustproof: protects it from dust, and could get rid of the pesky insects
● Dual-chip Three-way Dimming System: color temperature range from 2700K to 6500K, brightness range from 0.1Lm to 2000Lm
● bluetooth Remote Control: bluetooth remote controller allows you to remotely switch on and off freely
● APP Remote Control: control via smartphone by WiFi or bluetooth
● Mi Band Linkage: turns off automatically when you fall asleep
● Efficient Heat Dissipation: unibody aluminum plate maintains highly efficient cooling
Package Included:
1 x Yeelight YLXD01YL Ceiling Lamp
1 x Remote (including the battery)
Effective mosquito repellent
You can get an effective mosquito zapper with many advanced features from several popular selling brands, but check whether they are waterproof, portable, rechargeable, weatherproof and compact. The mosquito repellent with all such features is ideal for camping, you can go for “”outdoor mosquito zapper”:https://www.zapoutusa.com/product/rechargeable-mosquito-lantern/” from Zapout. This is specially designed for the purpose of camping, outing, trekking, and hiking.
