Yeah, the price for that gasket is a bit ridiculous.
You can get a 1kg spool of GITD filament for 20-40$. Time is the real cost obviously but that’s a tiny piece.
Let’s see, what’s the volume of that thing…multiply by this, carry to three, deduct that…uhm fuck all is the answer.
In case you’re wondering, we’re talking about less than half a cubic centimeter.
So a spool would net you, idk, 1500pcs or more.
I got curious how much material it would take and how long it would take so…
…I slapped together a representative model of that thing (~20x20x3mm with appropriate holes) and fed it to Cura.
Looks like you could print 56 of them at a time in an Ultimaker 3 and Cura estimates it would take a hair over 3 hours with the default “Fast” profile while using a whopping 32g of material (generic PLA AA 0.8).
And that’s at 0.2mm layer height, with a part like this I would bump it to 0.3mm layer height and have it only take ~2hrs15mins. Or roughly ~2½ minutes a piece.
Dropping the thickness to 2.5mm means it would take only 1hr50mins and use 26g of material.
Sure you can tune it further to save even more time but that’s fast enough.
There are 3D printing factories in China with a room full of printers so you could have a load of these made in no time at all.
Just for the giggles I looked on 3dhubs, punching in Shenzhen and some factory would charge ~800 USD for 999pcs and you could get them by next tuesday.
If some chinese flashlight company would do the ordering, handling, storage, shipping side of things, how much would they charge?
Could they do it for 5$ a piece incl. slow boat shipping?
On the other hand, Neal might be a few steps ahead of us. *checks his store just in case. Oh well let’s hope that FW3A pic is a sign of things to come!
For my Emisar D4, I just cut two small strips of GITD tape and put in under the optics in the shape of an X. Seems to work fine. I like the aux led of the D4S. I wish the FW3A had an aux led. GITD doesn’t last all that long.
The glow tape isn’t that green under normal lighting, its usually an “off-white” when I’ve seen it, just like watch lume.
I doubt it would change the tint much, especially when its placed under the business end of the optics where not very much light should be shining at it.
I’m having a slight issue with my light and I can’t seem to figure it out. For some reason, while I’m ramping up in the smooth ramp mode, sometimes it will just abruptly stop and shut completely off. Anyone got any ideas what I’m doing wrong? Here’s a video of what it’s doing https://giphy.com/gifs/ekvkxmNAyZY6Wk4AVW
That’s the main symptom of a switch tube contact issue. I haven’t seen it happen on my production sample, but I know the issue well from seeing it on earlier prototypes.
Loosen the tail a bit, loosen the head, then tighten the tail as much as you can, then tighten the head. The issue should go away.
If the issue returns, loosen the head, tighten the tail again as much as you can, then tighten the head. Try to keep the tail as tight as possible. And always tighten it tail-first.
Yes, but feeling certain isn’t the same thing as having accurate information. There’s a reason why there are so many adages and quotes about certainty, like counting chickens before they hatch.
