Wow....lots of reservations here. :-P
Can't wait to see what this will be about.
Some ideas - probably you’ll be doing these anyway but just thought I’d pop them in!
Optics, I believe there were 4 (item numbers 10507, 10508, 10509 & 10511 I think and what they do to throw etc) and where to buy them - I did see it in the main thread but like all the info it’s lost forever in a million posts.
Holsters that fit
Modding bits, glow tapes/ disks, trits etc. Someone even did drilled optics, but they were a little expensive for me sadly (a lot of work is involved in making them though)
Diffusers for the ‘play’ modes lightening , candle etc - the rubber cone/dome things
Batteries - their pros and cons with this particular light
I guess more ideas will follow from others when they get their lights and start playing
Thanks for the ideas Goose. Ideas welcome…
Yeah I’m working on it & should have it up later today after I get finished with a doctors appointment.
Last night TK asked a volunteer to do this… I could not refuse the ‘Light Goddess’ and the rest will be history.
@ Lux-Perpetua…. Yeah… I went “reservation” crazy. I figured better to many than not enough. I’ll just delete the unneeded ones later.
I'd have to say, I have some... reservations about this thread...
…. You won’t be dissappointed.
Would it be more useful to put the issues and fixes into a spreadsheet rather than another BLF thread?
Just thinking out-loud….and thanks for taking this one
Soon… ALL of BLF will be FW3A
CRX, i’m waiting for you to add your custom switch with trit installed to this thread. Then, I can PM you and you can take my money.
Maybe some smaller trits in a triangle around the tiny plastic switch nub?
My light is on it’s way, traveling by Yodel, which is always fun
From the pictures I have seen, for a single central vial install it looks like the centre nub in the steel cover can be ground down/ slotted, a hole or slot into that with a 6mm x 1.5mm trit & UV glue and then some playing around with the nub on the rubber switch boot. Maybe also use a thinner vial there.
Or as you say three trits in a triangle shape etc would look really nice too.
This is not going to be about mods or anything… it is just going to be a listing of simple things that TK can put a link to in the FW3A Thread OP… according to her…. IIUC.
I know …. Yodel! same here!
I’m kinda surprised someone on here doesn’t sort of mass produce some trit switches for this, once programmed the time and cost would be minimal - next to no materials either and the milling would take a matter of minutes. I could make some on the lathe, but no milling option sadly.
Thanks you for creating this thread, teacher.
I'm sure it will help a lot of BLF members.
GO TIGERS
My pleasure raccoon city. :+1:
Hopefully it will help those that need it.
This might be a topic for a more advanced guide, and it’s not strictly unique to the FW3A:
How about including some notes on calibrating the thermal sensor in Andúril? Might help some folks squeeze out a few extra seconds on turbo.
Also, I don’t see a link to the manual at all. Maybe include that near the top, at the very least.
Yeah right…
You been in the swamp to long buddy……
I hear you actually…. I wish it could ’somehow’ be us two at the end, 1 & 2.
I would honestly be good with either being 1.
As long as they both “showed up” & played that is. I couldn’t take a repeat of last year on our part at the end… :cry: . :person_facepalming: . :person_facepalming: …
RTR & GT
The FW3A uses standard 20mm triple stars compatible with the Carclo 20mm triple-TIR optic.
This means standard 20mm Noctigon triple stars fit perfectly.
Good idea.
It’s one of those things new users should know, along with “open the front, not the back”. It works a lot better after it’s calibrated, and it only needs to be done once.
nice thread!
thanks for the work
Thanks for putting this together!
