interested
[♛ FreemeGB] FireFlies E01 LUMINUS SST40W N5 5700K 2300lm Andúril 27100/18650 EDC Flashlight - ENDED
The mcpcb is only 20mm, with the solder wires and everything, I dont’ think it would be possible to fit aux leds
Interested. Thanks!
Plenty of room
Interested
There is one code available now but is not quite i predicted. If you MUST have the light right now, i can forward to you today.
FF direct sale will be available in a couple of days time.
They need to do some accounting work before that.
I will wait for the direct sale Freeme
interested
Interested
Interested
I’am in for 1 interested thanks
Interested!
Interested!
So Fireflies recommends to use
“battery discharge no big than 10A , Or it will cause damage to the emitter”
So using lower rated current batteries to protect the emitter, but wouldn’t this be dangerous for the batteries because it might run at maximum rated continuous current?
interested…
interested
NOT INTERESTED anymore, at least for now, with any FREEME GB’s since 2 other FREEME GB’s were just recently “ENDED” and the entire content of the first long detailed interest OP’s were just completely wiped out! Bad form. Just add “THREAD CLOSED” to the end of the existing subject title and PM the admin to close the thread to new posts.
No, the higher iR of the cells will prevent them from running at unsafe currents.
Its a legit way to limit a lights potential, lots of us around here do it. I run 35E’s in most of my lights for normal use then stick a 30Q or P26A in it for max output. It’s not like if a light draws 15A on a P26A it will still try to draw that from a 35E, the 35E (a 10A rated cell) will usually do about 7-9A in the same light because of its iR.
Interested
No code yet?
