Well, I was worried that SST-20 and FET were not a great combo. But it was at the edge of my understanding of the stuff so I was not sure. Thank you all for the confirmation.
These newer SST-40/8A high current linears Simon requested being made feature an Atmel MCU onboard. Playing with the sense resistor also helps. I will use one as it comes for a White Flat 2mm² in a C8 but inside an S2+ with LH351D I will replace the stock R005 with an R010 (4A) or R010 plus R050 (4.8A).
They have solder mask down at the spring base. Can fix that with Cu sheet + thermal glue but it is another bummer for my spring bypass technique.
Since your FET-driver crusade started, I never stopped thinking higher, and believe me, my thoughts have no limits. Unfortunately, reality does not listen to my wonderful thoughts and existing well-regulated drivers are often bulky or expensive, or at least have a medieval user interface that after I started using TomE’s and Toykeeper’s firmware, I will never tolerate.
So I keep thinking, and using my pleasant and convenient BLF-A6/bistro/biscotti/Narsil/Anduril flashlights, keep not noticing that regulation is not perfect, and in the meantime wait for the small and still powerful affordable current-regulated driver with TK-quality UI to appear from some heaven.
Same here. I love the idea of linear FET driven lights.
Power density is great.
Efficiency is slightly better than with our standard FET+1 or FET+N+1.
I don’t think the hardware is inherently expensive - though I am uncertain here.
Flexibility of adjusting current to match one’s needs is great. F.e. I’d love to PWM SST-20 with 2A at moon and limit to 4.5A at Turbo. Wouldn’t go particularly low but it would have good performance and consistently great light quality.
But such driver is not available.
There’s Texas Commander but it never took off.
There’s Lexel’s driver but it’s in progress.
There’s Led4Power driver but it lacks good UI.
There are several other drivers that have, yeah, medieval UI.
So for now we need to settle at sub-optimal choices. Like PWMing a FET to reduce current. Or adding large banks of 7135s. Or adding resistance. Or using only well-matched cells.
I really hate the state of affairs. But it is what it is and I am unable to do anything about it.
Reality does listen to your thoughts, albeit not everything you think is something you believe.
You allowed yourself to become addicted to those firmwares. Despite being your respectable choice, as any other addiction that is bad. And those last words I left in bold in the above quote are terrible.
In real life I can be be very tolerant, as that is often needed to operate well as a human being, but in my hobby I allow myself some plain intolerance at times
Non customizable UIs have slowly became intolerable to me… as well as Low CRI, gritty threads, mushy button, ringy beams, and so on… I’m a flashlight integrist
Nah, I am not keeping them, I can’t get them myself.
I tried yesterday to get my hands on the FA3 but the manufacture is holding them with an iron grip. All I managed to get were a few samples for myself and a few others.
I can get FD2 SST-20’s but I don’t know if it would be worth the hassle as I would need to get 500+.
Consider it a peace offering after all the bugging you about firmware issues lol.
I knew you like high CRI LED’s and tint mixing so when they said they were sending you a box anyways I asked them to send you a few of these LED’s as well. I think they were supposed to send some FD2 as well?
I am actually going to try tint mixing a 2700k from KD, the FA3 sample I have + a 5700-6500k 70CRI SST-20 in my EDC with a 10511 optic to see if the final tint can get that rosy range we love so much.
I did this with XP-G3’s before and the final tint was surprisingly good, I ran that setup in my EDC for the past 2-3 years.
If enough interest was shown I can get them but it is needless to say a big investment that I could not afford to hold onto long term. So I would need to know I could sell off most of them pretty quick.
Group buy pricing would be around $3 per LED I am guessing just to give an idea with discounts for higher quantities based on my talks yesterday. If I ordered 1000+ the prices would drop some but I kinda doubt there will be that much demand for FD2.
What is their reason for only selling the FD2 and not FA3? Would love some FA3 for the more rosy tint. If not, FD2 is still better than the current FB4 by far. Vinh might be interested in buying a bunch since he uses a bunch of the FB4 tints in his lights. Richard at MTN might be interested to stock some too if you can’t get the quantities you need.
Btw, output-wise the FA3 did just as well as the FB4 in the OP, 307 lm at 1A. The FD2 did 319 lumens. At 5 amps FA3 did 934 lm, FD2 980 lm (not using a copper hs like in the OP and graphite pad instead of thermal paste).
BlueSwordM recorded interest in 412 x 4000K SST-20 so far in a group buy thread he was running. He already made a group buy of 3500K, but 4000K has been on hold for a couple of months due to not being able to confirm availability of anything better than FB4.
Perhaps FD2 is good enough to start trying to get a 4000K group buy in motion again?
Interesting, while the FD2 is the best tint out yet I would guess that FA3 or better would be needed to gain that amount of interest. That is about what I figured the interest level would be if I could get the FA3.
I am guessing less then half the interest for FD2.
I know I would want some FD2’s to play with I would not stock up on them to use in a lot of lights, I would wait for something better to come along.
It is possible we could get enough interest to make an FD2 buy worth it. I would need to sell at least half of them right away to cover most of my costs minus the LED’s I plan to keep for myself.
