[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
So, freeme, what happened with all these ended posts?
Sorry for the copy and paste, but I would like to know what happened.
I think some numbers or driver info are important for this one as the 3v xhp50.2 is a pretty straight swap and gets the same output as a lot of stock single cell xhp70.2 lights and i think will get more throw as well, smaller emitter(s) with similar output?
Either way i’m probably not getting another one, partially because the 5$ xhp50.2 swap is so easy.
That said, i’m sure it’l be great bang for your buck like the first one is.
Please ignore those dated contents. All my latest deals will be found on 1theDeals and various social media networks.
No signup is required right now.
I did read about it a few months ago. From here? https://budgetlightforum.com/t/-/55685 If the result is that good, i can propose to BG too.
What will the numbers be?
3500Lumen/100Kcd?,Just a wild guess.
Interested. (for a neutral white)
OMG!
This is endless.
My wallet and piggy bank will be empty.
Interested in one NW. No glue please.
Interested.
Interested
Interested
Interested
Interested.
Based on the Convoy L6 70.2 smooth reflector is it safe to assume the FT03 70.2 should be around 2200-2400 lumens with 400-500 meters of throw?
I’m also assuming we’re looking at an extremely fast turbo step down due to the very small amount of heat sinking/thermal mass?
Interested
Interested for NW
The SST-40 already does that amount of lumens with significantly more throw than the XHP70.2 would have so that would be rather pointless.
I’m guessing 3800-4200 lumen, which again is kinda pointless unless you want a larger hotspot in my opinion since the 3v XHP50.2 can reach the same output with the original driver and will have more throw due to being a smaller emitter.
Interested!
Interested
Interested.
Interested
