I think some numbers or driver info are important for this one as the 3v xhp50.2 is a pretty straight swap and gets the same output as a lot of stock single cell xhp70.2 lights and i think will get more throw as well, smaller emitter(s) with similar output?
Either way i’m probably not getting another one, partially because the 5$ xhp50.2 swap is so easy.
That said, i’m sure it’l be great bang for your buck like the first one is.
The SST-40 already does that amount of lumens with significantly more throw than the XHP70.2 would have so that would be rather pointless.
I’m guessing 3800-4200 lumen, which again is kinda pointless unless you want a larger hotspot in my opinion since the 3v XHP50.2 can reach the same output with the original driver and will have more throw due to being a smaller emitter.
