I’am in for 1 interested thanks
[♛ FreemeGB] FireFlies E01 LUMINUS SST40W N5 5700K 2300lm Andúril 27100/18650 EDC Flashlight - ENDED
Interested!
Interested!
So Fireflies recommends to use
“battery discharge no big than 10A , Or it will cause damage to the emitter”
So using lower rated current batteries to protect the emitter, but wouldn’t this be dangerous for the batteries because it might run at maximum rated continuous current?
interested…
interested
NOT INTERESTED anymore, at least for now, with any FREEME GB’s since 2 other FREEME GB’s were just recently “ENDED” and the entire content of the first long detailed interest OP’s were just completely wiped out! Bad form. Just add “THREAD CLOSED” to the end of the existing subject title and PM the admin to close the thread to new posts.
No, the higher iR of the cells will prevent them from running at unsafe currents.
Its a legit way to limit a lights potential, lots of us around here do it. I run 35E’s in most of my lights for normal use then stick a 30Q or P26A in it for max output. It’s not like if a light draws 15A on a P26A it will still try to draw that from a 35E, the 35E (a 10A rated cell) will usually do about 7-9A in the same light because of its iR.
Interested
No code yet?
I like the design and size but I would’ve preferred 3x sst40
interested
Sending out deals in about 3hrs time. Do hurry if you want to grab one.
Valid till May 31, 2019 or first 100 orders.
Interested!! Thank you.
Interested please.
Freeme,this deal goes to banggood or nealsgadget?
FireFlies direct.
Hi freeme, is the code out yet? I’m interested but haven’t received the code
Codes sent on here? I’m interested
Me too
