My Imalent DX80 caught fire, vented smoke, almost exploded (replacement head arrived)
150 posts / 0 new
DBSAR
DBSAR's picture
Last seen: 1 day 14 hours ago
So as pick up to grab my Imalent DX80 before i went to bed to go up lock the door,(the flashlight was not used in a month) I went to turn it on and it began to hiss and vent smoke around the threads of the head burning my fingers, and blew the charge cap off, I immediately unthreaded the head off the battery tube, and it billowed smoke from the head driver area.. for now I placed the light parts outside incase for saftey. This light has very little use, and never run on its maximum mode for longer than a few seconds in the past. I ent Imalent a inquiry email, & expect them to fix this issue, and replace or refund this light or get a ton of backlash. This is the first time i ever got injured by a factory flashlight.
The lens area fill with acrid brown smoke in just seconds with the LEDS flickering while the light was hissing &, venting in my hands! Photos will be posted tomorrow.. right now at 1 am inhave to open my doors and windows to let the smoke and burn ing smell out of my house!
UPDATE: it appears to be a driver fire, (and in a sealed light it pressurized the head)
The battery pack still shows 16 volts. but attempting to get the retaining ring to remove the driver its seems to be fused to the back of the driver and tries to turn the entire part. Have anyone had a DX80 take apart before?
Below are photos of the smoke-filled lens and smoke residue on the battery cap:
The upper o-ring had failed, and hot smoke blew past the threads.
resulting smoke burn to my fingers, which were stinging all night. (i applied some burn cream & a band aid today)
-Here is a quick video explaining the DX80 incident from last night:
** (UPDATES, May,12,2019)** Imalent was quick to respond to to this incident, and they told me they will ship a new DX80 or the head to my vial DHL.
UPDATES,May,16,2019
The replacement head arrived today for the DX80. I thank Imalent for the fast & great customer service, and quick solution & replacement of the failed light.
Edited by: DBSAR on 05/16/2019 - 15:13
Mr.Scott
Last seen: 6 days 15 hours ago
Glad you are ok.
Was it the LED / driver smoking? Or the battery smoking?
the4ds9
the4ds9's picture
Last seen: 6 days 23 hours ago
My sincere condolences DBSAR. Sad Glad you were not seriously injured or killed. Tired
DBSAR
DBSAR's picture
Mr.Scott wrote:
Glad you are ok.
I dont know yet, it vented hot gas from the threaded area where the head threads to tje body.. it burned my hand bad before I dropped it
Mr.Scott
In the event of a Lithium-ion battery fire seek medical attention immediately.
SKV89
Last seen: 8 hours 36 min ago
Wow that is crazy man. I wonder what caused it. Does anyone know what batteries Imalent used in their battery pack?
I doubt Imalent monitors these forums. You might have better luck contacting them directly or through the dealer you bought it from. Good luck.
sb56637
sb56637's picture
Last seen: 3 hours 49 min ago
Shocked Shocked Shocked
Wow…. so glad it didn’t end up even worse for you or your property. But with that being said, this seems like wise advice:
Henk4U2
Henk4U2's picture
Last seen: 42 sec ago
Glad you survived! I think if one cell goes pearshaped, it’s going to be like a box of firecrackers! IMHO Imalent is is obliged to take very good care of you. After all, it’s a proprietary battery. They can’t hide behind the mantra that you did not handle some parts as well as you should have done. You can’t touch the innards. Maybe the Imalent people did not use well balanced cells. Be sure to make it the monkey on THEIR shoulder.
Seems they even have a Dutch website. Well, sort of. On the positieve side, the price certainly looks Dutch! But I seriously doubt if any Dutchman past the kindergarten age was involved. No contact info of any kind in the Netherlands. If something goes wrong, it’s going to be an RMA job.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
M3CSL
M3CSL's picture
Last seen: 1 year 2 weeks ago
this is horrible, but glad you are ok. Is this common with imalent lights?
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
mortuus
mortuus's picture
Last seen: 4 hours 43 min ago
wow crazy.. think now that imalent will soon release the 100,000 lumens light.. i cant imagine how bad that must be if something bad would happen that amount of power in your hands… Facepalm imalent should get banned from making such power lights if user safety is compromised…
can u take some pics how it looks? what cells is the dx80 even use, samsung 30qs ?
              つ ◕_◕ ༽つ
Firelight2
Firelight2's picture
Last seen: 1 hour 19 min ago
Wow! Glad to hear it didn’t explode and you’re all right. Shocked
You hadn’t used the light in a month? Maybe parasitic drain depleted the batteries in the interim. If the batteries in the battery pack depleted unevenly and are in series one of them may have ended up reverse-charging another one. Result is venting and fire. Sick
Doesn’t the DX80 use a proprietary battery pack though? It should have had circuitry to stop this kind of thing happening. Their QA seems a bit lax for a near $400 flashlight.
M4D M4X
M4D M4X's picture
Last seen: 5 hours 17 min ago
 can you please contact Imalent here: sales@imalent.com
they are very interested what happened with the light...
your description directs into a faulty driver I think?
what's the voltage of the cell pack atm?
they told me the pack uses 30Q cells which are very safe in chemistry and unlikely to explode. Also there is of course a safety circuit in the battery pack.
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
hIKARInoob
hIKARInoob's picture
If I’m not mistaken, the batterypack is 4S2P, and the safety circuit monitors each row of 4S cells, and not the individual cells.
Glad that DBSAR is ok.
M4D M4X
M4D M4X's picture
the chemistry of the individual cells should prevent explosion in case the safety component is defect or something else happened.
but again: something bad happened in the head and not in the pack I think.
as long as the current drawn from the battery pack did not exceed the Amps it was designed for its okay at that end
deals.m4dm4x.com
AlexGT
AlexGT's picture
Last seen: 4 days 12 hours ago
Scary, glad you are OK and hope you get restitution fast.
hIKARInoob
The symptoms of failure do remind me of the very first generation DX80 before the major recall.
mrwolf
Glad you are ok.
Jack Kellar
Jack Kellar's picture
Last seen: 16 hours 43 min ago
Hot damn, DBSAR, dodged a grenade there. Glad it was only the scare and no real damage happened.
Aaaaaand now I have even less desire to purchase an Imalent, if that was even possible.
TheAuditor
Last seen: 7 min 35 sec ago
I have a DT70 and the batteries would discharge over a month or so. Because of this post I just went and checked that the batteries are not in the flashlight, and they weren’t Smile
Bonum commune communitatis.
Yarp.
hIKARInoob
I also have the DT70 and DT35 (love ‘em both!). Big plus is that the batteries are parallel, protected, and you can monitor each battery as well.
TheAuditor
Good to know
Yarp.
djozz
djozz's picture
Last seen: 3 min 17 sec ago
It sounds like maybe the batteries did not vent (I would actually be surprised with 30Q’s) but the driver seriously got on fire. But if so, I’m sure the pictures will reveal that.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 2 days ago
Oh yeah, that’s for sure the driver.
I still remember when I killed my Haikelite MT01 driver.
Quite a bit of smoke from the inductor and the like.
Didn’t kill the LED at least.
Quality 18650s like the Samsung 30Q will not explode or vent without something physically triggering it, as the internal PTC would shut it off very quickly.
That means there was a driver short, as unused cells will not do anything if you just turn it on.
How the symptoms occurred reminds me of a driver short.
TLDR: Probably a driver short from a lack of QC during wire soldering.
mattadores
mattadores's picture
Very glad to hear that you were able to contain a potential disaster! That could’ve ended up very, very badly especially if the flashlight developed enough pressure to break the threads and actually force the bottom battery cap off of the light. I too have a DX80 and the bottom battery cap is at least 8 threads deep. The pressure required to bust that open could’ve easily put the cells in a possible failure scenario and made this a catastrophe.
Glad you’re alright and hope that your house doesn’t stink too badly! Burning electronic smoke/stench is awful
PS- I’m 99% certain the DX80 is an 8× 18650 configuration not 6× 18650
DBSAR
DBSAR's picture
Firelight2
Glad to hear it wasn’t the battery.
Sounds like rather than trying to disassemble the light further you should contact Imalent. M4D M4X says they are very interested in investigating the cause. Hopefully they will also repair or replace your light as well as ensuring that this doesn’t happen again in other lights.
On the upside, we have now identified another advantage of USB charging in flashlights: The USB cover serves as an emergency vent. Wink
mattadores
Can you post a photo of the threads on the battery cap & battery tube?
M3CSL
M3CSL's picture
Thanks for the pictures, that looks rather frightening. Imagine this happened in a car while driving or similar.
DBSAR
DBSAR's picture
The threads are ok, but dirty now from the smoke gassing past them, it blew the upper o ring out though.
DBSAR
DBSAR's picture
they are very interested what happened with the light…
what’s the voltage of the cell pack atm?
ok thanks, i sent them an inquiry on my incident.
DBSAR
DBSAR's picture
more photos:
showing the melted copper traces & burned driver board, ( the area under the plastic cap) I can not get the driver or head apart, even with a strap wrench, and will wait until i hear back from Imalent..
resulting smoke burn to my fingers.
