FW3A mod thread. Post yours!
Thanks!
. Here is the Funky Square-ish Beam it produces… :smiley:
Yeah. Are you going to change it back, or try other emitters?
Oh my gosh !
CRI70, not a good Duv, desaturates most colors (over-saturates green-yellowish), lot of hue shifts and colors fidelity sucks.
I only ordered a Convoy desert S2+ with XP-L HI 3A and was done with XP-L HI. How could people always asking for this expensive and ugly thing for the sake of a tint and a bit longer but ephemeral turbo ?
Quick and nice work still KB! Which 106xx optic did you use?
I’ll be curious to read the report on the sliced DA0GF4RTs. I’m guessing not quite as nice looking as the 219B, about the same cd/lumen, but higher max output.
Thank you so much for the quad beam, looks funky indeed.
Thermal paste is not applied evenly.
if it is possible…
Please reapply the thermal paste.
Driver
Reflash newest firmware.
anduril.2019-04-24.fw3a-219.hex(For Nichia 219B_V1)
anduril.2019-04-24.fw3a.hex
CREE XP-L Hi 3D (5000K)
Nichia 219B_V1 4000K R9080
Samsung LH351D 4000K 90CRI
XPL Hi、219B、LH351D
Ramp Ceiling (moment),steel_lumen
XPL Hi:1020
219B:656
LH351D:887
Amazing pictures and insight, thanks for uploading!
Great lights and mods, the only aspect that would irritate me personally is the rabbit :wink:
Changed the emitters in my modded FW3A again tonight. Currently it’s sporting the following:
  • Two XPL HI 5D
  • One XPL HI 3D
  • Lee 279 minus-green filter.
  • Carclo 10507 optic.
I’ll give this a shot and see how I like it.
I wonder if Manker quad lens would fit in it? Should require trimming the TIR less, so be more efficient.
+1Except I think the rabbit looks cool. :+1:
I have nothing against rabbits, I just prefer cats or dogs :smiley:
621
Maybe just off it…… I’ll play with it all weekend then see?
:open_mouth: We have a candle stand(s) in the bathroom. I put it in one of the tall ones that has a metal shade with cut outs of Stars in it, it sure does look great! :wink: :+1:
You should at least try it with a 10622 before killing it off. The 10621 produces a significantly worse beam.
After seeing the optic installed in the bezel I doubt I’ll be wasting any time with the quad. I really am not a fan of tiny triples/quads anyway TBH. In my
experience, ‘real world efficacy’ would be better in the units of lux/W. 20MM Carclos don’t deliver that IMO.
That is exactly what I was thinking, the Astrolux/ Manker optic is 22mm vs the Carclo 24mm.
I cannot find any MCPCBs for it though? The optic is still available through BG I think.
It could possibly be installed without modification depending on the head threads?
Where is my light dammit! :smiley:
I’m not going to make my FW3A into a quad as I have the SR4 where I used the smaller manker quad optics.
The SR4 is solid copper with a lot more mass and can barely manage the heat on full pelt.
I think a quad setup in the FW3A is pointless unless you use W1/ W2 emitters.
Optics comparison:
CRX, what is the height difference?
Manker:
Front flat to optic opening is 6.66mm, Front to legs end 8.34mm
Carclo:
Front flat to optic opening is 5.06mm, Front to legs end 7.54mm
So 0.8mm.
