Imalent might try some funny business if you keep trying to disassemble the light.
See this thread: https://budgetlightforum.com/t/-/54892
VOB did a full tear down and the only way to access the driver was to completely destroy the head of the light
Imalent may try to claim foul play if you start ripping pieces apart that they’ve purposefully designed to never come apart
I wonder what would be the best way to present your case to them? If you present yourself as an average ignorant consumer they could try to take advantage of your “ignorance” and give you the runaround. On the other hand, if you make it clear you are a flashlight expert that is active on a large forum, they might think you were monkeying around with something on the light.
Didn’t know drivers can catch fire. I hope they figure out what caused it. With the MS18 with 8×21700 high drain cells, it would be even more dangerous. I’m planning to buy the MS18 and R90TS too.
I think we’re all really interested in how Imalent is going to respond to this.
Basically a week or two before they launch their mothership $700-$800 100,000 lumen light, their two year old flagship that’s still for sale nearly blows up.
I can’t help but think that it’s just a plain bad decision to drop any more money on this brand. I get mfg defects but a mega light almost blowing up… like someone mentioned, what if that had happened to someone other than you and they would’ve just dropped it and run… I assume it could’ve caught fire internally and it’s only so much heat before those cells vent…
lol other cheap Chinese mfgs have sharp edges and fake drivers that just don’t work or fail. Blowing up after you’ve completed a full recall… That’s another level!
It is difficult to know how to approach Imalent on this case. They are aware that the DX80 has some serious failure issues form past incidents, but in my case my light as indicated in my past topics & posts on the DX80 has indicated i left this light completely stock without modifying it in any way. Also they can know that a well known flashlight user member of a well known forum who got injured by their defective DX80 can also damage their already fragile reputation with back lash. my fingers are still stinging a bit from the hot smoke gas from it.
The battery pack on this light can provide nearly 50+ amps at 15 volts to a shorting driver, and in a air tight enclosed capsule like the head of the DX80 it can be a bad situation with a ton of arcing and a fire building up pressure. (its what happened here)
if i had not quickly un-threadded the battery tube to release the building pressure in the head and cut off the current, (which is where the venting hot smoke burned my hand) it would have likely blown out the lens sending glass shrapnel forward, or worse.
Very, very glad your cells didn’t vent. Cells venting is indeed terrifying and I’m sure we’ve all watched the videos.
(I’m a vaper so I’ve looked into it extensively)
Only about a month ago it actually reached another level… A Texas man had his vape set wrong and was drawing way to many amps so it vented. The difference between his situation and all the rest was that it exploded with so much force it launched a piece of shrapnel into his neck which tore his carotid artery and killed him.
Newlumen’s MS12 had a fan that didn’t work. He surprisingly received a full MS12 replacement after many, many months of reporting the problem and we all thought would be hopeless.
Wow, I’m interested to hear what Imalent’s reaction is to this. I know stuff happens and there are faults in production with anything but this could have been worse than it was.
I’m uploading a video now explaining the DX80 incident, will be online shortly. (I sent Imalent an email inquiring on it, but unknown when i will hear back, or if i will hear back…
Great video. also couldn’t help but laugh midway through to the haaawwwkrrr pheww lol
ya that’s what I expected. now amplify the cells by 8 and cause the venting by heat (looks like you did it by short circuit?). I’ve seen youtubes where they force venting by use of a heat gun and that consistently provides the most explosive results
