[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
Any idea when it will be available?
If its single cell format same as the FT03 it would have to be a boost driver? I don’t think the 26350 we have can do that many amps like 7 max?
Interested depending on driver info. Will it be using a boost driver instead of FET?
Interested depending on price.
Interested in NW
Ugh - you're right, not sure then. A MtnE style boost is probably wayyy too much $$$, and yes, limited amps. Hhmm. Ok, I get it now - the 3V XHP50.2 might be a better option, but in theory, you should get more efficiency of lumens/amp out of the 70 with a decent boost driver. I really dunno why our boost driver prices are sooo much higher than what they do in China, but then again, lot of the China boost (or buck) drivers we've used turned out to be unreliable in the long run, probably over amped them or the quality of the parts, etc.
Interested
Interested.
How’s Convoy only pushing 5300 lumens with a 2S configuration if you can push up to 7000 with a single cell?
Interested.
See my response above... Had a senior moment, an ooops, brain fart ........
Interested for 2
Interested depending on output
Interested.
interested
interested
Im interested
Anyone know why the FT02 is smaller but more expensive than the FT03?
Pictures not showing an XHP35 or XHP70.2! its an SST-40
Interested !
