Yeh, I mentioned that up nyah (#9). Nice.
Kewl, so it is a b/b converter…
They sound useful enough to get a pile more. :laughing:
This LM2577S single switcher seems uncommon to me, I've had it on my wishlist for ages but finally decided it was time to give it a try.
Another buck boost topology:
That one has end current percentage turn lamp setting and two switcher ICs: LM2577S + LM2596S. Besides this, the above board is marked as XW036FR4, whereas the one discussed here is marked as XW036NFR4 (check it in my #28 reply).
Wow… buy 5, get 1 at 5% off! That’s a whopping 1% off the total!
Now Maw kin git that operashun…
So whut’re the 3 trimpots for? Voltage, current, and…?
3rd trimpot is usually for end of charge (low current) detection adjustment
That last kind of converter theorically has a lower efficiency as it's made with a boost converter followed by a buck converter so you have to account for the two stages losses
Hmm, that can come in handy.
The setting on the OP boards is a fixed ratio instead of adjustable, then.
Still trying to figure out where the turn-signal comes in…
The turn signal is meant to indicate at which point the current output is lower than the given ratio, for battery charging duties namely. It is set fixed as 1/10th in the OP module.
I have an interesting question, because as I see this module it looks like it is parallelizing friendly. First of all the diode at the output makes it reverse current inmune. Next question is, is it reasonably possible to use the same control trimpots/potentiometers for two or more modules? The idea is to use common voltage and current trimpots/potentiometers, this way the modules should share load with great balance…
Cheers ^:)
Sorry i don't understand what you mean with "turn-signal"
Here is a simplified schematic for a CC/CV buck driver :
The two "FB" points are connected together
R3 sets the max voltage
R2 sets the max current, D2 might be a led indicating that the converter is worlking in constant current mode
The third trimmer sets the reference voltage on an other comparator for lighting a led indicating the end of charge
Nah, it’s a joke. Like the funny kind, only different.
In car manuals, they’re called “turn lamps”, not “turn signals”, just like “CHMSL” vs “3rd brake light”. So when the spex for this donk kept referring to a “turn lamp”, well…
That doesn’t usually work, as the converters will have very slightly different feedback voltages.
For example, if you put two in parallel, one might go to standby at 0.60V of feedback and the other might go to standby at 0.61V. What happens then is that one will stop converting before the other, so that the other ends up bearing all the load and either frying or shutting down. At that point, the first one has to bear all the load and either fries or shuts down as well.
You might get away with it if you use trimpots on each module to adjust for the different feedback voltages, in addition to your main control potentiometer, and add load-balancing power resistors in series with your module outputs, but that gets very fiddly, especially if you’re doing it for more than one control.
You can also run into problems with things like thermal effects under load making the feedback voltages drift at different rates, so you end up back where you started with one module trying to bear the entire load again.
Easier if you just buy a more powerful converter module in the first place.
I’ve also found that sometimes the 3rd pot is for setting the LVP. Cut power when Vin drops below set threshold.
@Lightbringer : ok i got it ;)
The problem is that when i get it i like your kind of humor but sometimes, even if i understand the words, i miss the cultural reference to understand the pun
@maukka : i didn't know that one TY (i hope that when doing that they allow for enough hystheresis to avoid on/off/on/... cycle)
++1
Well, I understand the reasons to prefer a single, more powerful module versus 2 or more in parallel. Anyway, and in this particular case and partly thanks to the anti-reverse output SEPIC topology, 2 or more modules can then be parallelled by properly tuning the output voltage trimpot in each of 'em to match as close as possible, then swapping their current trimpots with a dual, triple, quad, etc. potentiometer. The only concern I see is that, in my experience with cheap logarithmic dual pots, their gangs aren't finely matched, they're like 5% tolerance. This should be nothing major, though, with regards to load balancing. Or does it?
OK, now you’re into a zone where I haven’t actually tried the arrangement you’re suggesting
If you can get the module voltages to stay in alignment (the hard part), then current control deviations from multi-gang potentiometer tolerances are less likely to be a problem. The trick there will probably be to keep the maximum current setting per module at the module maximum minus the largest deviation that the potentiometer could introduce. That way, you shouldn’t overload any one module.
Although those deviations will prevent the modules sharing the loads equally when current limiting kicks in, they should settle in reasonable states. For example, let’s say you have 2 modules, each nominally bearing 50% of the load, and ±10% deviation from the multi-gang potentiometer. You could then have one module bearing 45% and the other bearing 55% in the worst case, which may eventually shorten the life of the module that runs hotter, but probably won’t cause major issues.
Once again, this is not something I’ve actually tried, so don’t rely too heavily on my thoughts here.
Having said that, you might also be able to get the current limiting to catch any overloads on modules whose voltages become misaligned, but that would add still another tolerance to factor in, which means that you’d have to set the overall current limit lower, costing you a bit more still of your total output capacity.
I’ll be interested to see how you get on with this experiment
Talk about circular links…
Despite sometimes I do not fully understand some of your jokes due to cultural reasons, amusing as usual, Lolbringer.
Wellp, over there I pointed here, and over here I pointed there.
That joke I got without effort Lightbringer, that was culture-independent enough. ;-)
Tested both my modules a few hours ago, both buck well with load and I found no need for further testing being it an LM2577. With the board oriented sideways with input at the left and output at the right, the current trimpot adjustment is counter-clockwise (right way decreasing). Didn't pay much attention to the leds but both were on (and red) when in CC mode. Left side led is bi-color, lights up green when powered on unloaded.
I have not spoken of this before but, when using these kind of converters fed from AC, what about efficiency? I mean, if we feed these off a regulated mains switching power supply the combined efficiency (mains supply efficiency times converter efficiency) does not look exactly great. Besides, when using these converter modules we do not need a constant voltage power supply, a classic unregulated AC-DC supply can do and is supper efficient (mains transformer plus bridge rectifier and capacitor). Unregulated supplies were all the rage years ago but this is not the case now so, what's the deal? I also do not see the massive and bulky AC-AC “gearbox” transformers of yesteryear in the newer supplies, they look comparatively tiny and lightweight now, did they improve that much?
Tranformer and filtering capacitors for the old type power supply work at mains frequency (50-60HZ) while the switching AC/DC PS work at much higher frequency (typical 100kHz-1MHz) so it can be a lot smaller and cheaper and i don't expect a non regulated switching PS to be much cheaper than a regulated one so we have regulated output.
To tell the Truth most of the old power supplies (at least the low power ones) where not that efficient ! The cheap transformers had a lot of loss. Do you remember those old plug mounted power supplies that were hot even with no load ?
Non regulated supplies were a thing because most of the time the regulation was on the "user" side and usually used a linear regulation that was way less efficient than any modern switching supply.
Wellp, my transformer is of decent quality I think, made a picture of a couple units I have ≈3 years ago:
The one at the right. Haven't checked if it gets warm just by being plugged, though.
You say they switch at much higher frequency, 0K. I do not usually see two transformers in power supplies (some do), one for frequency (?) and the other for voltage. Are they integrated in the same device? I mean, do I connect 230VAC 50Hz by one side and get, let's say, 12VAC 100KHz by the other side? LoL!
How are these devices called? I find it takes more effort to find relevant results now with search engines than what used to be in the past, prior to the philistine consumer market crowd internet invasion. Miss the days of the uncensored internet with pure logic search engines unhampered from spelling correction duties.
Cheers
Seems my previous answer was lost :(
The kind of converter i am talking about is what you find in laptop brick power supply or the small mains to USB converters (and many others).
There are several ways to do that but the easiest (and somewhat durty) way is to rectify the AC mains with diodes and filter it with a 400V capacitor, then the high voltage DC is switched (Mosfet) at high frequency (100k-1MHz) and sent to a transformer whith a low voltage secondary winding, then this low voltage is rectified and filtered to give low voltage DC
The chip that control the switching usually take care of the regulation but in order to keep the low voltage DC side insulated from the mains side the feedback is done through an auxilary winding or an optocoupler
Edit : That's how you get power supplies that are able to run from 110V or 230V without any configuration switch
