Interested for 2
Interested depending on output
Interested.
interested
interested
Im interested
Anyone know why the FT02 is smaller but more expensive than the FT03?
Pictures not showing an XHP35 or XHP70.2! its an SST-40
Interested !
Interested
Because of the driver. FT02 uses boost driver which is more expensive.
But I think XHP70.2 is too much for this host. Simply not enough mass in the head and no fins just those little ribs on the neck. An L2 head is 90g more weight and it has smaller diameter. With SST40 it has good balance but XHP70.2 is a no go for me in this light. Even a 3V XHP50.2 can make a lot of heat and current.
Interested NW
I would like two as well.
Thanks
Interested
Interested
So how will this differ from the previous ft03?
Interested
Led will be XHP 70.2
Driver has to be different (Voltage is not the same) which probably means different UI.
Maybe OP reflector.
And that’s about it.
whats the lumen numbers on this ?
i agree that XHP50.2 3V is can fit in same driver.
i hope freeme can manage 2 choice
1.xhp50.2 3v on same driver depend not over 35dollar and
2.xhp70.2 with new driver 3X.XX dollar
