Thanks, here is a code coupon for SP40 if you want this valid for Aliexpress APP, from 8th to 15th, May, scan to get and use it when purchase, if any problem in using, contact with the customer service ,they may help adjust the order amount by hand
Usually, those XP-L HD Sofirn uses will come with a CCT between 5350K and 5750K, so a bit on the coldwhite side. But I cannot tell for sure what they are using here. I would be surprised if they used a warmer tint than usual. Modes on the SP40 are: 5lm (Low), 90lm (Medium), 450lm (High) and 1,200lm (Turbo).
Thank you for your reply! Pretty nice mode spacing but I wish it had ramping, and a moonlight mode for up close use since its a headlamp. Might be still get one
Seconded! But I’m also happy to see this new entry to the budget 18650 headlamp market. Probably going to be my first decent headlamp, now that I got the feel for a cheap one with the Boruit D10.
USB micro-B is a pretty widespread standard, compact AND inexpensive. An USB type-C connector is bigger, more complex and more expensive, without real advantages here besides reversibility.
In the past I replaced some USB micro-B male connectors for a sloppy friend in a DIY power bank with a permanently attached micro-B output cable, they can be bought rock bottom cheap with shells (and I've seen cheaper).
On the other hand, USB type-C male connectors: 5x pieces, 10x pieces. Without :facepalm: shells.
Of course the above is for comparison purposes, just made the type-C thing search out of curiosity. It serves as comparison because as it is understandable the female part cost is thereabouts.
I could say a chair or even the wheel are outdated. I like outdated stuff. ;-)
Devices are pushing the usb-c standard for a variety of reasons, and adoption is picking up. I have less and less need for micro-USB and have fewer and fewer of the cables hanging around. I wouldn't want a new light, which I'd expect to last years, to end up being my last darn micro-USB device.
Well people, this headlamp has been designed with a USB micro-B input port. I can understand all sorts of scaremonger reasons against, but in all honesty it is not my problem. I think and believe different. Nothing is random fellows. My ports do not break, I keep them fit and clean. If yours do, address the cause and/or fix the problem.
The headlamp could also been fitted with a standard O:) ∅3.5 × 1.3mm DC female plug, it could also have :-D worked with it. So, you can consider yourselves fortunate it uses a nowadays' more widespread and standardized USB micro-B connector. 0K, no more fuel to this fire of yours.
