My understanding is thermal paste should never be reused. To get best thermal contact you should always clean off the old thermal paste and apply a fresh layer anytime you remove the star.
@ GOOSE ā¦ Yeah, I know what you mean. If it wasnāt so sad it would be almost funny. Why not just do it 100%ā¦ or at least 99%.
There is a knife company very close to where ai liveā¦ they do the same thing. They build a very decent knife but the fit nā finish is most often 90% - 95%. My buddy & I just look at each other & shake our heads.
All it would take is just a very, very tiny bit of extra effort or attention and it would make all the difference in the worldā¦ā¦ instead of being ājust good enoughā.
Seems easy on the paper but this is the difference between a big name and a random inferior brand. The hardest is to achieve this last percentage closer to perfection. But not anyone can do it or can afford to do it.
Yepā¦ as far as performance these knive are not inferior, they preform well. Itās just the last little bit of fitment of handle slabs, one more tap on a pin to close a tiny gap, etc., etc.
But like you said, that seperates the men from the boys. And it also seperates price points.
Maybe they are where they want to be in the market place???
Yeah lol, or maybe we are just fussy moaning old gits! :disguised_face: But I donāt think so really, itās not a big ask to have it done properly, I would expect it on a $10 light for the masses, but a $35 for enthusiastsā¦ well maybe not.
/\ ā¦ I am a somewhat picky old fart, but I donāt even think things like this is being picky. Itās just like you saidā¦ do it right. The first timeā¦
Expected results: lamp turns on/off, smooth ramping of light level from floor to ceiling. (very similar to the Q8 behavior)
Actual results: lamp turns on, switches between ceiling, and turbo mode. lamp will not shut off without removing the battery.
Now, I purchased two FW3A lamps, one works exactly as expected, the other lamp does not function like my Q8. It could be that the lamp is in some odd mode, but it does not function as expected.
Battery used: Sanyo UR18650NSX, also tried LG HG2 - no change.
Has anyone got any advice on further troubleshooting?
This worked for me. Thanks. My symptoms were, I would just get a blink as I was tightening the head on but other than that the light was unresponsive. I had taken both ends off a few times when I was trying to figure out what was going on. But nothing worked until I followed these instructions.
I followed these directions and now the lamp comes on with a rapid seizure inducing bright flash, and wont turn off without removing the battery. At least it is a different response.
EDIT:
Since I figured that there had to be something going on in the tail, I carefully disassembled the tail switch, and found it full of some kind of grey grit. Carefully cleaned the switch out, and reassembled the switch into the tail - took a couple of tries, but the lamp now appears to be working - however it is stuck in step mode.
I think it is the issues we will see in this thread that drove Liteflux out of business.
Itās easy to make the electrical connection in a twisty, but once you add a clicky there is trouble.
The FW3A takes the idea of a clicky one step higher, that second signal you have to send from the tail to the driver is painfully difficult.
The good news is that if you werenāt mechanically inclined this will be a great primer.
The better news is that once youāve got everything snugged down and you understand all the points of failure it will be no big deal.
HDS solved the problem but their implementation adds some thickness to the body tube and there may be patent issues and they cost way more.
There is a product called DeOxit or similar that might be applied to the connections in the tail before assembly. Supposed to remove and prevent oxidation.
Iām SURE some of the crafty folks on BLF have a budget formulation that does just as good.
(just searched ādeoxitā on BLF and oh boy, thereās a lot)
Liteflux and the FW3A use virtually the same method of connecting the electronic switch: An inner tube insulated from the outer tube serves as the electrical contact. However, the FW3A relies on anodizing for insulation while Liteflux used a separate plastic tube between the inner and outer tubes.
Iāve owned many Liteflux and the insulation was never a problem. It was always the points of conduction; the end of the tubes. These have just barely started selling and this issue is showing up. There will be a tsunami of users who have malfunctioning lights. A local BLF member texted me with issues on the very day his light arrived, random turn-on, no button control, etc. Not what most people expect from a new light. What happened to him will happen to many.
No need to defend the design, itās just problematic and folks will have to learn how to take it apart. They will be better for it.
This is definitely not a light for first responders or any mission critical applications, but if youāre not afraid to crack it open it should be a great EDC.
The local member I mentioned fixed his by loosening and tightening tail cap.
WLE, I have complete confidence that BLF will crack the code that Liteflux could not.
Liteflux was considered a boutique brand and I donāt think they sold as many as the FW3A will. Also I think the very nature of the users and the support forum is completely different.
There are some very serious brainiacs here and I doubt this issue will go unsolved.
I havenāt received mine yet so I canāt investigate any fixes or best practices yet, but will post anything once I get mine and can check them out.
The local member I mentioned had very positive things to say about the beam and tint.
i am slated for mine to come tomorrrow or next day
iām a banzai fixer too, though I sort of hope mine ājust worksā
i had issues like with the DQG tiny and others, so i know about troubleshooting this kind of thing
the annoying thing is, it is a simple circuit but you cannot observe anything directly - it all happens in the sealed light, and you can;t measure voltages and currrents under real conditions, all you can do is hypothesize and test
so far we have seen tube contact, heat sink compound and driver looseness all as problems
